crankshaft pulley
Old Dec 6, 2015 | 02:48 PM
blee49's Avatar
crankshaft pulley
I have 1970 350 olds pulled out of my 50 chevy truck. I started stripping the motor to paint. I can't get the crank pulley off. I removed the 4 small bolts, its loose but won't pull off. do you have to remove the large crank shaft center bolt ? Thanks
Old Dec 6, 2015 | 02:58 PM
RetroRanger's Avatar
72 Olds CS
nope should just wiggle off after the 4 bolts are off
Old Dec 6, 2015 | 07:21 PM
Octania's Avatar
maybe tap a thin blade like a paint scraper in between the pulley and balancer face.
Old Dec 7, 2015 | 06:30 AM
It is not uncommon for the pulley to require a little, ah, "persuasion" to come off. Also be aware that there is a separate reinforcement plate in front of the pulley that will also come off.
1950 Model Olds
Tech Editor's Desk
Jul 20, 2011 09:02 AM
hawks70
Jun 15, 2011 11:07 AM
D Appeldorn
May 24, 2010 09:21 AM
rustycragars
Dec 3, 2009 10:46 AM
sssingo
Nov 9, 2008 03:47 PM
