large center bolt on 1970 350 crankshaft pulley
Old June 15th, 2011, 09:24 AM
hawks70's Avatar
What size socket to get this off ? Help please! Don't want to have to make multiple trips to get right size. Thanks!
hawks70 is offline
Old June 15th, 2011, 10:05 AM
Lady72nRob71's Avatar
A guaranteed way to get the right side is to crawl under the car with a small piece of paper (post it note will work fine) and fold it the width of the bolt head. Crawl out, measure with a ruler and you have it!
BTW - creative avitar!
Lady72nRob71 is offline
Old June 15th, 2011, 10:12 AM
hawks70's Avatar
True. I'd had that thought. Won't be hard to do. Engine is on stand bieng torn down for rebuild. Was just taking a shot to see if anyone knew to save the guess work. Thanks though !
hawks70 is offline
Old June 15th, 2011, 10:42 AM
It is also possible that long ago that the original bolt could have been replaced with one with a slightly different head size, so measuing your own would be most accurate.
Old June 15th, 2011, 10:44 AM
Oldsmaniac's Avatar
I am pretty sure it is 1 1/8 socket. Then you will need a puller to get the balancer off.
Oldsmaniac is offline
Old June 15th, 2011, 11:07 AM
svnt442's Avatar
1 1/8"
svnt442 is offline
hawks70's Avatar
Ok. Cool. The puller I have. So I'm good there. Thanks for the info. Was wondering about the bolt bieng changed. I know the timing set was replaced in 92, but that is the extent of "internal" repairs on the engine until now. Hopefully will be ordering re ring kit this week and cam and lifters next check. Then next will be oil,fuel,and water pumps. Last will be carb,intake,and headers.
hawks70 is offline
1950 Model Olds
Tech Editor's Desk
July 20th, 2011 09:02 AM
laker
April 3rd, 2011 06:10 AM
D Appeldorn
May 24th, 2010 09:21 AM
rustycragars
December 3rd, 2009 10:46 AM
sssingo
November 9th, 2008 03:47 PM
Quick Reply: large center bolt on 1970 350 crankshaft pulley
