View Full Version : Small Blocks
- 1956 Super 88 heater control valve
- 1970 350
- 1966 F85, 4 bbl conversion
- 1979 - 1980 L34 350 Cubic Inch V8 clarification
- 1968 Olds Non A/C Power Steering Pulley
- 350 oil pan vs 455
- 403 stroker crank
- 1970 350 Oldsmobile 6 heads
- Engine from my vista
- 1984 5a heads 1976 350 engine
- Air cleaner spacers
- Motor mounts?
- Edelbrock Intake 37111
- Used header value
- Olds 215 main cap/ rover main caps?
- 67 C/S 330 camshaft bank angle
- New pushrod broken
- Valve almost went through retainer
- 350 how to identifying casting numbers
- Correct Throttle Cable?
- 67 C/S 330 4 barrel Spark Plus needed
- Clearance issue & Aluminum head ?'s
- 350 In A 64 Timing Chain Alignment Marks
- Exhaust Leaks
- 1977 Cutlass 350 identification.
- Oil pressure sending unit removal
- Rochester 2bbl Hesitation
- Engine Dieseling/Run-On - Fouled Plugs?
- What is this part?
- Opinions on Head Mod: SBO Big Valve Job
- 403 Crankshaft problem
- Fuel Return - Yay/Nay & How To...
- 64 #1 heads on 72 350
- Newbie stupid question about transmission fluid
- 67 C/S oil filter
- Radiator Fit
- Exhaust Manifold Flange Gasket
- Valve cover grommets
- Hot air choke issues
- Rebuilt engine only starts with starting fluid, immediately dies
- Heads
- Hei distributor
- 67 cutlass 330 performance
- 1971 Cutlass Supreme
- 350 Pulley/Serpentine Conversion - Pros/Cons?
- Advice?
- 1972 350
- The infamous neoprene timing gear.
- Cold Weather Questions
- 330 engine screeching
- i'm blue
- Valve issue?
- 64 vs 65 330
- valve lash 350 rocket
- $1900 to rebuild #5 heads???
- 64 330 Intake 45 Degree?
- 1985 307 Interchangeability 1976 350 4bbl
- Adding Oil Additive a good idea?
- Engine temperature cycling at highway speeds.
- Help identify Quadrajet
- Polyurethane engine mounts?
- Best Inake a carb for 350
- Won't shut off
- 1953 4bbl heater hose routing
- Identity of oil pressure sending unit and flasher
- 403 harmonic balancer?
- New rebuild need help!!
- Aluminum radiator for '56 Olds?
- Olds 307 cold start got the SHAKES
- Dropped Condenser screw into distributor.HELP
- 1972 350 Engine won't start on first attempt since resto- please help troubleshoot
- Helpppp, 350 rocket 1979 camshaft specs.
- Bearing question
- Charcoal canister necessary 1972 cutlass.
- 403 engine
- Breather 1972 cutlass 350
- How to lubricate points 1972 cutlass 350
- Engine Rebuild Questions
- Decoding a 307 3GP355043
- HEI Distributor for 324 Rocket
- 1966 Oldsmobile Cutlass 330 timing issue
- Engine rebuild?
- Valve Cover Recommendation
- Should fan spin freely 72 350
- Dashpot adjustment 72 olds 350 bbl
- Heater control valve vacuum routing
- New Dist for "stock" 330
- 350 heads on a 307
- Edelbrock Intake Manifolds 2711 Questions
- Carb for 72 350
- 1973 350 2BBL Choke Heater Tubes
- A/C 72 supreme 350
- '72 350 vacuum diagram
- 1971 fuel pump
- Will a '68-'70 olds rocket 350 fit in an 86 Grand Prix?
- 69 350
- Intake manifold gasket for stock 1972 350
- 350 issue
- Vibration Noise
- PSI Compression on 75 350 factory engine
- NGK Spark Plugs
- Help Identifying my engine
- Counting the costs, 403 top end build
- Fast Idle Solenoid for Quick Fuel 670?
- Power steering pump pulley stuck
- spark plug wires
- HELP! Top End Rebuild 78 Olds 350
- Edelbrock Intake Manifold 3711
- 1970 350 runs, then dies, then runs again
- Idling Rough, Stalling, and Knocking OH MY!!!
- Ready to start 1972 350 4bbl auto trans oldsmobile
- the infamous 307
- 1965 Olds Rochester Carb Bolts Torque
- Short Header Downpipe
- Distributor vacuum control switch 1972 350
- Missing part in carb (choke)
- Vacuum connections Rochester 4 jet
- O2 Wideband Sensor Location - Dual X-Pipe
- Building 403 questions.
- FiTech issues
- Oil Dipstick
- possible donor car rescue...what tools to bring?
- What Year Motor?
- Choke electric or not?
- What’s a “throttle retarder”?
- The thread size for the ports left and right of the Thermostat on a Performer or RPM
- 76 350 Shuddering/Jerking when Accelerating
- Dash pot- what do I need to complete this?
- #8 heads cracked
- Do pushrods need assembly lube?
- Faulty gauge or serious issue
- 403 in a G body
- 350 cam questions
- HEI Distributors
- 90’s v6
- Cooling System 434ci SBO
- 77 oldsmobile 350 help please
- 403 7111 intake and C heads
- cylinder heads
- Oil pressure too high?
- Breaking in camshaft with no torque converter
- 68 Cutlas Vacuum
- 72 Cutlass 350 motor lifters question
- Starter
- 1969 with 2 engines...my best options and what would you do
- Looking to find year of engine
- ‘72 Olds 350 Cylinder Pressure Specs
- 1970 oldsmobile cutlass with 1977 350 rocket
- 68 Cutlass 350
- 403 with #2 heads 3711 intake don’t fit?
- Oil Pressure
- 350 rocket freeze out plug please help
- Help diagnose this please.
- Max rpm
- Intake Upgrade - 70 350
- Long Heater Hose Route
- Hard to Start a 2nd Time in Same Day
- 350 2BBL Intake Problems
- 1969 oldsmobile cutlass 350. Dies after a small uphill rev
- 67 Cutlass supreme 330 rebuild
- Olds 307 Y with rochester4barrel
- Rear main seal
- Raise The Compression On A 72
- 1970 350 cutlass supreme misfire at idle
- Quick Fuel carb questions
- Pulley alignment 330 in 65 Cutlass
- Can someone tell me about this engine
- Diagnosing Oil Consumption
- Engine break in
- 330 questions
- Olds 350 rocket
- Engine torque specs
- 1964 330ci oil pump
- Lunati Voodoo 262/268
- Balancer timing mark position 1970 350?
- Maincaps
- Need help with 403 w/ #6 heads running lean & oil in intake
- Timing chain cover.
- Crank Key Sticking Out
- Lifters not spinning i
- Exhaust Flange Stud bolts
- Sleeve on harmonic balancer
- 350 water pump rebuild
- 1964 330 worth rebuilding
- I see Thornton listened, new improved SBO shorty header
- '72 350 2bbl random backfiring at idle
- 5A heads on a 350?
- Stuck carburetor
- 350 Intake Gasket Failure and Replacement Advice
- Swapping out intake manifolds and lifter check
- first time out racing with the new 350 olds
- Distributor gear oiling
- Can someone please help me identify this part
- '76 350: Carburetor Barely Warm but Boiling!
- Fuel pump failure 1964 Olds 330 engine
- Replacement radiator
- Head#8 3501976 egr
- Harmonic balancer bolt torque?
- Exhaust leak from manifold
- 330 Roller Cam & Rockers
- Head Gasket Sealant
- 307 Bogging Real Bad
- Heater Core Replacement
- Carb gasket
- 71 Cutlass fan shroud
- Rocket 350 feeling a bit sluggish
- 1971 350 Tuning
- 1950 303 hydramatic, performance bolt ons
- Valve covers?
- 330 heads
- timing sprocket key sticks out past end of crankshaft
- #8 heads left or right side
- Limited hei advance
- New timing chain slack
- 1976 Cutlass Supreme Vacuum issue
- Intake gasket, valve covers and HEI
- Mechanical Fuel Pump Brand - does it matter??
- 68 olds 350 multiple questions of ignorance
- Won't start?
- Oil pressure jumping around
- Numbers matching again ;)
- 330 Sluggish or is this normal?
- Cam swap or gear swap
- 67 olds header options
- SBO NOS 350 Block
- Found a SMW 403
- Radiator Suggestions
- Milky looking oil
- 1969 oldsmobile cutlass 350. What is the proper oil pressure
- Lost the thread about a 330-350 swap.
- Headers don't fit!!
- What type of engine oil on a 350 rocket with 400miles
- Randomly stalling out in Idle/Park/Drive
- Extremely high idle
- 1980 442 engine build
- 1977-1980 350 Ignition timing
- Always degree your Olds cam!
- EGR System Pros/Cons
- 525+HP SBO 350 Motor Mounts?
- Torque Wrenches...
- Will harmonic balancer come loose if I take the crankshaft pulley off?
- Oil Dipstick Tube....
- Tips and pointers for 403 "build" with #6 heads needed
- "Winter Work - Almost Complete"...
- 350 pushrod length swapping heads
- Edelbrock Intake Heater Hose Fitting
- PCV hitting rocker
- 77 Seville
- Oil pump
