525+HP SBO 350 Motor Mounts?
Hello everyone!
I'll son be installing a SBO built by Mark R (cutlassefi) that just dyno'd 530hp and 580tq. I'll be using factory rubber motor mounts, and will also be strapping the drivers side of the engine to the frame, as well.
I'm just curious if there is any other reinforcement I should do with this power on the stock 1972 Cutlass Convertible frame for the motor mounts? I heard large power can crack/stress the exact area of the frame where the motor mounts bolt down to, and I wasn't sure if there is anything I need to worry about.
I appreciate all insights to this inquiry!
My BBO had less vibration with the solid motor mounts on my drag car. I purchased them from Mondello when Joe was still alive. The Chrysler chassis manual recommends 1 of the 3 mounting points for engine/transmission combinations be rubber to avoid cracks.
Dick Miller racing
http://store.dickmillerracing.com/se...d+engine+mount
Buy some stock mounts. On the driver side drill it and use a bolt to turn it into a semi solid mount by bolting the 2 halves and limiting them from splitting apart or ripping under torque. I use a threaded tube and heim joints to strap the engine to the frame. ( adjuster bar from lakewood traction action bars for coil cars )
Dick Miller racing
