Always degree your Olds cam!
Old April 7th, 2019, 06:30 PM
72 Cutlass Ponca City OK
bigrbandit's Avatar
I got the bottom end of the 403 assembled this weekend and decided to degree the cam. Your typical sealed power/wolverine/Edelbrock 214/224 474 /496. (Yes I know it is not optimal but it's better than what was in it and has been on my garage for years). Anyhow compared to the cam card it came out 6 degrees retarded when installed straight up. I have never had a chevy cam come up more than a couple degrees off. Each crank tooth is 10 deg, and by moving to the advanced gear position I got it to come out dead on. I have heard about olds came being off, guess it is true. Will be way better than the stock cam and chain with almost an inch of play that came out. degree that cam!
bigrbandit is offline
Old April 7th, 2019, 08:44 PM
Phantom Phixer
Charlie Jones's Avatar
I had to set the cam in my 394 eight degrees retarded to get it " straight up " .
Turns out , the crankshaft keyway was off by more than five degrees alone .
Yes , if you have an " adjustable " timing set , it is well worth degreeing the cam .
Charlie Jones is offline
Old April 8th, 2019, 04:12 AM
cutlassefi's Avatar
I’m guessing both of you used the “generic” 3 key way sets offered by many?
cutlassefi is offline
Old April 8th, 2019, 07:07 AM
bigrbandit's Avatar
I used the Comp Cams 2113. I have used the Edelbrock 7813 set in the past and found it to be way off as well as more expensive. What would you recommend? It would probably be worth $20 extra bucks to have a set that is right the first time, or has more adjustment, but if the crank or cam is off, it doesn't help a lot. This one seems nice and tight, and this double roller set doesn't require clearancing the fuel pump arm or slot like the Edelbrock set did. The set that came out of the engine was a generic replacement chain that didn't have a nylon cam gear, but was not adjustable and was super sloppy.
Old April 8th, 2019, 07:14 AM
Phantom Phixer
I used a 9 way set provided by Ross Racing Engines .
The thing that really made mine off was the 5 degree error in the crank keyway .
Old April 8th, 2019, 10:01 PM
cutlassefi's Avatar
Just an FYI, most all of the three keyway sets are made by one of two companies, and they’re all not worth the box they come in. I had a Comp cams set that was 11* off on the +4 setting.
CJ I’m curious as to how you determined the crank was off 5*.
Thanks.
Old April 9th, 2019, 05:50 AM
Phantom Phixer
Thanks.
I had already determined that the whole works was off by eight degrees when I degreed the cam .
When I installed the balancer , which had just been re-built by The Damper Doctor , it was off by five and a half degrees on the timing marks . .
I figured the error was in the crank keyway and not the balancer .
I will probably have to use a " dial back " timing light to set the timing .
Old April 9th, 2019, 07:24 AM
Bernard Mondello's Avatar
I couldn't agree more!
https://m.facebook.com/story.php?sto...08309059257851
Bernard Mondello Racing Enterprises
Bernard Mondello is offline
Old April 9th, 2019, 07:53 AM
cutlassefi's Avatar
“I will probably have to use a " dial back " timing light to set the timing “
What does that have to do with cam timing? You would use the dial back timing light to check total advance for ignition not the Cam. I’m confused here.
Old April 9th, 2019, 10:33 PM
Phantom Phixer
The balancer was just rebuilt by Damper Dr. They take great care to make sure the timing mark is in the correct relationship to the keyway .
When I installed the balancer I checked it against " true top dead center " (as found with a dial indicator ) and at true TDC the timing mark was at five degrees advanced .
My ignition is supposed to be set at 10 degrees advanced . With a five degree error that's a total of fifteen degrees , which is off the timing scale in "guess territory " .
Hence the need for a dial back timing light .
You are right about the cam timing having nothing to do with the ignition timing or the timing mark on the balancer . Except that an error in indexing the keyway to the center of the #1 rod journal will affect both .
Perhaps my crankshaft guy didn't get the crank journals indexed properly to the keyway ?
Old April 10th, 2019, 06:37 AM
OLDSter Ralph's Avatar
One thing is sure, its off 5 degrees. I would either mark the balancer at the correct ZERO or modify the timing scale to read correctly.
OLDSter Ralph is offline
Old April 11th, 2019, 07:32 PM
BillK's Avatar
I used a Cloyes stock replacement set on the 307 from my Wife's Buick last year. I used a Crane hydraulic roller that was ground very close to stock specs and it came in right on the money.
Also .... good tip on the damper. I check them on every engine I build. I actually have found very few that are not correct.
BillK is offline
Dr. Oldsmobile
January 15th, 2019 02:47 PM
bert442
July 30th, 2015 12:13 PM
rcdynamic88
May 22nd, 2015 11:42 AM
iam2fast4u86
June 9th, 2009 05:13 PM
mp71conv
December 27th, 2008 05:50 AM
Quick Reply: Always degree your Olds cam!
