Camshaft Alignment / Front to Back
Old Jul 30, 2015 | 11:30 AM
bert442's Avatar
Unhappy Camshaft Alignment / Front to Back
Hello All,
I installed a Crane Cam in my 1968 350 Olds back in the mid 80’s. I think it was called a Crane Fireball Cam. The specs are long lost. The engine has very little run time on it since then. It was a newly re-built engine, new pistons and the whole deal, I just didn’t like the cam that was in it.
I have the top end apart and the lifters don’t seem to line up with the cam lobes. The lifters are running approximately 20% off the lobe towards the front of the engine. Meaning that it looks like the cam is too far back in the engine.
I don’t see how this can be. Wouldn’t the timing chain and sprockets hold the cam in its proper position? (a new Crane double roller timing gear and chain set was installed with the new cam).
What holds the cam in the proper position, front to back?
Thanks in advance for the Help !! ,
Bert
Old Jul 30, 2015 | 12:05 PM
The lifters will not sit completely on the cam lobes and is held in place by the distributor. The reason the lifters are offset is to allow them to spin in the bores.
Old Jul 30, 2015 | 12:13 PM
bert442's Avatar
Thanks !!
I think I'll skip out of work early and go home and put it back together.
Bert
cutlass47
Suspension & Handling
Feb 22, 2025 08:39 AM
#1CutlassSupreme
Body work
Mar 27, 2015 10:00 AM
Frank3
Jan 31, 2012 11:52 PM
joesw31
Jul 10, 2011 01:33 PM
todd66442
Tech Editor's Desk
Aug 12, 2008 07:43 PM
