Crank Key Sticking Out
Old Jun 22, 2019 | 04:41 PM
kiloman_11's Avatar
Putting my 350 back together and the original crank Key is sticking out beyond the face of the crank. What's going on here? Is it possible the crankshaft is out of position or what?
Old Jun 22, 2019 | 06:32 PM
Just tap it back in, it probably shifted when you removed the balancer.
Old Jun 22, 2019 | 06:42 PM
kiloman_11's Avatar
You misunderstand, I'm assembling the engine. And the key doesn't want to go any further than that. Hammer or no hammer.
Old Jun 22, 2019 | 06:48 PM
Ok, remove it and grind the end a bit until its flush, then put it back on.
Old Jun 22, 2019 | 06:50 PM
You could also try putting the key in the freezer one hour grease the key-way and key and try again.
kiloman_11's Avatar
But the key came out of this engine when I disassembled it. My question wasn't whether or not a key can be shortened, my question is why would it not fit in now.
Old Jun 22, 2019 | 06:55 PM
You can fiddle with it and flip it around in different positions to see if it will go flush. It has nothing to do with crank position it simply sits in a slot. Again, if you don't want to fiddle with it simply grind a bit off. Put some lube on the seal and balancer before sliding it in.
Old Jun 23, 2019 | 03:28 AM
The balancer bottoms against the crank gear and oil slinger. There is clearance between the tip of the crank and the inside flange on the balancer. This is a non-issue. Put the balancer on, torque the bolt, and stop worrying about this.
Old Jun 23, 2019 | 04:46 AM
cutlassefi's Avatar
the balancer bottoms against the crank gear and oil slinger. There is clearance between the tip of the crank and the inside flange on the balancer. This is a non-issue. Put the balancer on, torque the bolt, and stop worrying about this.
x2.
Old Jun 24, 2019 | 04:37 AM
BillK's Avatar
I have one sitting here that I just balanced and it is exactly the same. Not an issue.
AMCOLDS
Dec 13, 2018 07:32 PM
Kyron219
Jun 11, 2018 10:20 AM
rpinnt
Jan 11, 2018 09:55 AM
MyFathersOldsmobile
Jul 8, 2016 01:01 PM
BosMobile
May 21, 2009 01:09 PM
