Harmonic balancer bolt torque?
Old May 29, 2019 | 07:22 PM
mother$hip89's Avatar
Anyone know a good way to hold the crank still while getting the bolt to 300 ft lbs? I'm thinking a clamp on the flywheel but I'm worried it might damage the flywheel or bearings.
Old May 29, 2019 | 07:29 PM
I used a large screwdriver through one of the bolt holes in the flex plate, rotated the engine until the screwdriver was wedged against the block.
Old May 30, 2019 | 05:19 AM
Run to Rund's Avatar
On a stick car, you can thread a bolt into an unused pressure plate bolt hole, from the engine side. You need "only" 160 ft-lb with the bolt threads oiled.
Old May 30, 2019 | 05:36 AM
ELY442's Avatar
I use 2 long bolts with a shoulder and screw it all the way into harmonic balancer, leaving the shoulder exposed, and then I use a pry bar and stick it between the 2 bolts and let it wedge against the floor.
Old May 30, 2019 | 05:46 AM
boese1978's Avatar
Drop the converter cover and use a tire iron to hold the flywheel. I have a friend that puts the car in gear, blocks the tires and then torques it.
Old May 30, 2019 | 05:46 PM
BillK's Avatar
Too bad you are not closer. I made a tool that bolts to the four pulley bolts and holds it from moving.
maddoctor
May 21, 2018 05:37 AM
Bfg
Apr 3, 2017 06:32 PM
alburk
Jun 27, 2016 05:59 PM
805cut
Jun 18, 2012 02:42 PM
Redog
Oct 5, 2010 05:27 PM
