Harmonic balancer bolt torque?
Anyone know a good way to hold the crank still while getting the bolt to 300 ft lbs? I'm thinking a clamp on the flywheel but I'm worried it might damage the flywheel or bearings.
I use 2 long bolts with a shoulder and screw it all the way into harmonic balancer, leaving the shoulder exposed, and then I use a pry bar and stick it between the 2 bolts and let it wedge against the floor.
