Lunati Voodoo 262/268
Old Jun 25, 2019 | 04:58 PM
bw1339's Avatar
What static compression range would be optimal for this cam? A friend of mine wants to put into his 350, and he's about 8.7:1 compression. I fear it might be a bit low.
Thanks.
Old Jun 26, 2019 | 07:16 AM
oddball's Avatar
Well, it's not entirely awful, but still mismatched. I'd expect idle to be terrible and very little vacuum. I've run that level of cam in a small block with about 9.5:1 compression and it was a real fun build but took a lot of work to get an acceptable idle, especially with A/C and power brakes.
How certain is he about the 8.7:1? A lot of the stock replacement stuff ends up lower compression than advertised. Replacement pistons sit further down in the hole than OE, head gaskets are thicker now than they used to be, etc.
Old Jun 26, 2019 | 09:21 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
If he wants a Voodoo cam, I wouldn't go bigger than the one below it. The smallest Voodoo or the smallest two High Efficiency series cams may be better.
Old Jun 26, 2019 | 03:05 PM
bw1339's Avatar
It is my friend's math. What's the optimal compression range for that cam on pump gas and steel heads?
Thank you.
Old Jun 27, 2019 | 06:40 AM
oddball's Avatar
More in the 9.5:1 range. Ignition timing will be critical to control ping.
Old Jun 27, 2019 | 06:38 PM
bw1339's Avatar
Thanks.
Old Jul 28, 2020 | 01:26 PM
Delta 88 Johnny's Avatar
I realize this is an old thread, but just wanted to share my experience with this cam if this subject is still of interest to anyone.
I have a 1974 Delta 88 convertible with 350 engine I had rebuilt several years ago, approx 9-1 compression with aftermarket
pistons, cylinder head milling, and an adjustable valve train. I chose this cam because of great results I had with the similar
Voodoo 262/268 cam for my mildly built 9-1 383 1970 Corvette. The Olds now has almost stock level vacuum and idle is set
about 725 RPM. Idle is noticeable, but definitely not crazy. I later ditched my troublesome Quadrajet for a Holley Sniper fuel
injection system with timing control, made possible by easily modifying a computer controlled HEI distributor from a 1985 307
Olds engine. Lunati's recommendation was their cam one step smaller, considering weight of this car, but I have zero regrets
for choosing the 262/268. Has great power and torque off idle to at least 5500 RPM. This big boat really takes off when you
kick it down in passing gear, fortunately Olds used the 3.08 axle this year. Perhaps a less modified engine would be better off
with the smaller Voodoo cam, but this one sure works great with my combination.
Old Jul 28, 2020 | 04:25 PM
cutlassefi's Avatar
I have a 1974 Delta 88 convertible with 350 engine I had rebuilt several years ago, approx 9-1 compression with aftermarket pistons, cylinder head milling, and an adjustable valve train. I chose this cam because of great results I had with the similar Voodoo 262/268 cam for my mildly built 9-1 383 1970 Corvette. The Olds now has almost stock level vacuum and idle is set about 725 RPM. Idle is noticeable, but definitely not crazy. I later ditched my troublesome Quadrajet for a Holley Sniper fuel injection system with timing control, made possible by easily modifying a computer controlled HEI distributor from a 1985 307 Olds engine. Lunati's recommendation was their cam one step smaller, considering weight of this car, but I have zero regrets for choosing the 262/268. Has great power and torque off idle to at least 5500 RPM. This big boat really takes off when you kick it down in passing gear, fortunately Olds used the 3.08 axle this year. Perhaps a less modified engine would be better off with the smaller Voodoo cam, but this one sure works great with my combination.
A little easier to read this way.
Old Feb 5, 2022 | 07:12 PM
bw1339's Avatar
Out of curiosity - Many years ago I built a 455 with L2323F pistons and that cam (Voodoo 262/268). I didn't surface the block or heads. Used an off-the shelf head gasket (0.040"ish), so compression is likely in the low 9s if I'm lucky. Cranking compression is 150PSI across the board. Does this sound reasonable for this cam?
Thanks.
TheBigBlueBoat
Jan 16, 2017 08:51 AM
jag1886
Aug 23, 2013 02:40 PM
Nasty455
Mar 10, 2012 07:28 PM
1973olds98
Oct 26, 2010 08:50 AM
cbeatty
May 11, 2010 07:17 AM
