330 engine screeching
Old Dec 20, 2019 | 06:10 PM
Macksolds's Avatar
Vehicle over heated and acquired a loud screeching noise. I’ve changed the water pump, thermostat, belts, harmonic balancer, and crank seal. I removed the belts and found that the sound is coming from harmonic balancer area. Coolant in pan is from replacing water pump
File Type: mov
Old Dec 21, 2019 | 05:15 AM
Ozzie's Avatar
Your description makes it sound like the noise started after the overheating, and was already there when the harmonic balancer was changed. I'm wondering how severe the overheating was. It sounds like something is scraping (rubbing) on something it shouldn't. You could try to isolate the noise a bit more with a stethoscope. Check to see if the oil pressure is normal. I'm assuming that the problem which caused the overheating has been corrected.
Old Dec 21, 2019 | 05:40 AM
Macksolds's Avatar
Car was running fine before I had replaced all parts noted. It had over heated day 2 of owning it. I’m going to look at the starter and crank bearings next if it’s not those I’m probably in deep pocket trouble
Old Dec 21, 2019 | 06:56 AM
Fuel pump maybe? Did you have the timing cover off, change timing chain, oil slinger washer on backwards?
Old Dec 21, 2019 | 07:47 AM
don71's Avatar
same but different
Long shot...are you sure the balancer is in good condition? They slip on the hub sometimes and can walk backwards to the cover.
Old Dec 21, 2019 | 09:37 AM
Macksolds's Avatar
Balancer is new but I didn’t add a sleeve to it. Not sure if that makes a difference? Fuel pump is brand new and haven’t touched timing chain or cover
.Rocket.Man.
Jun 10, 2015 05:20 PM
64OLDSPILE
Dec 5, 2012 07:02 AM
defiant1
Apr 2, 2011 05:11 PM
1964F85
Oct 8, 2010 09:30 AM
silverriff
Sep 19, 2009 06:19 PM
