Mechanical Fuel Pump Brand - does it matter??
Old May 5, 2019 | 03:38 PM
ddd777's Avatar
Question Mechanical Fuel Pump Brand - does it matter??
For a replacement mechanical fuel pump are there better brands than others?
Airtex?
Delphi?
GMB?
The restoration houses seem to have very expensive ones that I am guessing are the same as I can purchase at my local parts store, or am I missing something?
Old May 5, 2019 | 04:08 PM
I use either Carter or Airtex from the local auto parts store. As you said, they are the same thing that the resto houses sell; buying locally makes returns, warranty replacement, etc a lot easier.
Old May 5, 2019 | 07:28 PM
dragline's Avatar
Whatever pump you buy, it might be a good idea to install a fuel pressure gauge you can see while driving. This will give you a good idea of how the pump is performing under all driving conditions. Carter has a good rep., I don't know if AC Delco still builds fuel pumps.
Old May 5, 2019 | 07:38 PM
Fpcopo's Avatar
I don’t think AC Delco builds anything now. Everything I’ve seen from them is outsourced
Old May 6, 2019 | 01:16 PM
ddd777's Avatar
fuel pressure gauge
Originally Posted by dragline
Whatever pump you buy, it might be a good idea to install a fuel pressure gauge you can see while driving. This will give you a good idea of how the pump is performing under all driving conditions. .
@dragline That is an interesting idea. Assume you just add a T to the outlet line?
Old May 6, 2019 | 01:17 PM
ddd777's Avatar
Thumbs up
Thanks @Fun71 . Ended up ordering an Airtex...
Cameron Boomer
Apr 4, 2017 01:53 PM
KQQLCAT
Sep 20, 2015 05:49 PM
ed burke
Jan 10, 2014 04:07 PM
Hairy Olds
Apr 21, 2013 06:04 AM
geckonz08
Aug 12, 2008 08:49 PM
