Hot air choke issues
Old Jan 8, 2020 | 07:30 PM
70indyolds's Avatar
First off, I hope you all had a fantastic holiday season and a happy New year!
I'm trying to get the factory choke to operate on my 1970 Cutlass cruiser. It has a 350 olds and the factory 2 jet carb. I recently had the carb rebuilt, installed new choke tubes as well as a choke stove. However the choke just loosely moves. Is there a guide or issue I should be looking for?
J.R.
Old Jan 8, 2020 | 09:17 PM
OLDSter Ralph's Avatar
Do you mean it flops open or closed with very little resistance ?
1. It looks like the white line on the black plastic choke spring cover should point toward on of the pointed things left of the top choke cover screw.
2. Is the choke spring connected inside the choke housing ?
3. Is the choke spring installed in the correct direction ?
Old Jan 9, 2020 | 06:44 AM
70indyolds's Avatar
yes, it flops open and closed with no resistance.
1) the white line on the choke cover is in the middle of all the ridges.
2) I'll check the choke spring connection
3) and the the choke spring connection
Old Jan 9, 2020 | 07:10 AM
Sounds like the choke bi-metal spring is not connected on both ends.
A. I recall reading on a thread that the the 2 GC carb had the choke spring coiled in the opposite direction of a Quadrajet. You may want to verify this. Joe P was the one who mentioned coil direction.
B. You need a slight amount of pre-load on the choke spring to close it. As the bimetal spring gets warm, it grows longer and relieves pressure to hold the choke closed. You can fine tune the choke setting a ridge or two when you have things squared away.
oldolds88
Feb 5, 2017 07:38 PM
flatlander442
Mar 3, 2016 05:51 PM
Gunfreak25
Feb 11, 2011 02:44 AM
HouTXCutlass
Oct 4, 2010 11:54 AM
justinj
Nov 5, 2008 06:07 PM
