Do pushrods need assembly lube?
Old Aug 27, 2019 | 03:48 PM
mother$hip89's Avatar
Do pushrods need assembly lube or does priming the engine do the job fine?
Old Aug 27, 2019 | 03:52 PM
442Harv's Avatar
If you prime, probably no, but if you want to that is not a problem, I'm not sure where assembly lube could be a problem, as to much in the oil, but I think either way will work.
Old Aug 27, 2019 | 04:40 PM
cutlassefi's Avatar
I use a drop of bearing guard on each end before assembly.
Old Aug 27, 2019 | 04:41 PM
BillK's Avatar
I always use some. I hate putting stuff together dry.
Old Aug 27, 2019 | 07:12 PM
Just a dab of Lubriplate 105 around the sides of the ball ends, don't clog the hole in the center.
Old Aug 27, 2019 | 07:30 PM
FN723's Avatar
Might as well lube them. It will either help or do nothing. Certainly doesn't take long to do.
Old Sep 4, 2019 | 05:57 PM
grego21's Avatar
I used to always use CMD Extreme Pressure Lube, just a bit on both ends, but any high pressure lube will work. I am not a big fan of the moly-graphite lube you get at the parts stores, it clogs the oil holes to easy. We had to blow the pushrods out with air once when the rockers would not prime because the moly-graphite stuff plugged the oil holes up.
Best of luck and hope it goes together well.
Kennybill
Oct 1, 2018 08:40 AM
stratoblues
Sep 1, 2014 06:52 AM
Geoff Pauers
Feb 10, 2014 05:17 AM
montvaleplace
Oct 19, 2011 07:35 PM
71cuttyS
Feb 13, 2008 10:05 AM
