Maincaps
Old Jun 25, 2019 | 03:14 PM
Bluerocket76's Avatar
Blue flamed rocket
Maincaps
Just came back from machine shop.1976 350 sbo ,He showed me that someone rounded off were the main caps sit just enough that he doesn't want to guarantee the work could I use a griddle to stop the main caps from walking and studs
Old Jun 26, 2019 | 10:25 AM
BillK's Avatar
Not sure what part exactly is rounded off ??? How about a picture ?
Old Jun 26, 2019 | 04:46 PM
Blue flamed rocket
Main cap saddle
Right were the main caps sit on the saddle were the bolts screw in the edges are kinda rounded off he saying that the caps will move and it will give improper thrust clearance
Old Jun 26, 2019 | 05:48 PM
cutlassefi's Avatar
Originally Posted by Bluerocket76
Right where the main caps sit on the saddle, where the bolts screw in the edges. They’re kinda rounded off, he’s saying that the caps will move and it will give improper thrust clearance
Sometimes you can peen those over to make them tighter. However the thrust isn’t the only thing effected. If any or all are loose then the overall alignment will be compromised. If you use studs that will help in keeping them located where they need to be but it still depends on how loose they are to begin with.
DROLDS707172
Dec 3, 2018 06:08 PM
Bernhard
May 26, 2018 09:47 PM
oldsmike1972
Jul 28, 2016 09:32 AM
72cuttys
Aug 30, 2012 09:05 AM
stlbluesbrother
Wheels and Tires
Jun 24, 2012 02:27 PM
