Dropped Condenser screw into distributor.HELP
HI All. Hate to look like a dummy, but I need some help. I've managed to drop one of the condenser screws into the distributor. I probably shouldn't have been trying to do anything with a bad back, but I'm a typical stupid man. Is there any easy way to retrieve the screw from the distributor body without pulling the distributor on my '64 330? There's gotta be a way....
Thanks for the help and not laughing too loudly
Try to locate it by eye, bend something like a brake tube or coat hanger, put something on the end of the tube/wire such as strip caulk or thick grease to grab it OR...like oldcutlass suggested pull the distributor. May be able to shop vac it out using tubing to step-down the size of the hose.
Good luck!!!
Good luck!!!
