What's the secret to removing the distributor?
Old Apr 24, 2014 | 11:42 AM
Tim305's Avatar
1969 cutlass convertible
I have removed the clamp completely rotated the rotor counterclockwise while pulling up and it comes up about an inch or two and stops. Gently wiggled but it will not come out. Is there some secret I'm missing?
Old Apr 24, 2014 | 11:51 AM
NHolds's Avatar
Pull harder would be my suggestion.
Old Apr 24, 2014 | 11:53 AM
Keep pulling / whacking at it.
There's nothing else holding it in except for a film of dried gunk.
Old Apr 24, 2014 | 12:01 PM
NHolds's Avatar
I always like the saying... Yank it like a monkey in a mango tree.....
Old Apr 24, 2014 | 12:14 PM
I use a small hammer and some wood to tap on the underside of the housing.
Old Apr 24, 2014 | 12:31 PM
If the tapping won't work, put a small piece of wood under the housing and lever it with a pry bar. I had one on a 73 455 that I swear was cast in place. I had to lever it to get it loose. When it popped, it literally jumped up about 3 or 4" and then was an easy lift out. Sometimes these parts that never get touched just need to be treated like your wife, not your girlfriend....
Old Apr 24, 2014 | 12:33 PM
Run to Rund's Avatar
I have seen some where the hexagonal oil pump drive is galled in the recess of the gear. If so, you might end up with the retaining rings getting stripped off the hex drive shaft and the shaft coming out with the distributor.
Old Apr 24, 2014 | 03:43 PM
jag1886's Avatar
I use a standard crow bar and a lot of WD-40, usually pops out easy that way. The factory o-ring gets hard as a rock which makes it so hard to get out, I don't know why you are pulling it but you will need a new o-ring before you put it back in. I had to order o-rings here in Boise as no one stocked them.
Old Apr 24, 2014 | 09:23 PM
RAMBOW's Avatar
Ben
x2 on what everyone else said.
The oil pump driveshaft is a hex shape- and fits in a recess in the bottom of the distrib- After years in place they are likely stuck together thats why it comes up a couple inches then is stuck- its the retainer clip of the driveshaft keeping it in place.
When you do get it out- put a dab of anti-seize in opening on the bottom of the distrib to help avoid the problem next time you need to pull it.
Old Apr 25, 2014 | 12:46 PM
Tim305's Avatar
Ok the woodblock small hammer tapping worked great. Only took a couple taps. I guess I just couldn't get enough leverage standing on my head and pulling. Thank you guys for the advice. Now I'm going to pay y'all back by letting you take your shots at me. I learned never leave a hole unplugged. The edelbrock intake bolt kit actually had two different size heads. The short bolts are bigger. While trying to switch sockets one flipped off flew a foot in the are and dropped into the distributor hole nothing but net. I could not hit that if I tried. Went fishing with a magnet and got it out
Old Apr 25, 2014 | 01:10 PM
freds cutty's Avatar
That's my luck glad you got it out funny story
Old Apr 25, 2014 | 02:20 PM
Swoopy's Avatar
Swish... Good O'l Murphy!
glad it all worked out.
Old Apr 25, 2014 | 06:02 PM
Yeah, it's another what are the chances moment. Glad your were able to fish it out, now stuff a rag in it.
Old Apr 26, 2014 | 11:23 AM
Just thought of something. Removing a distributor is a lot like sculpting something. Just take away everything from around it that doesn't look like the distributor....
Old Apr 26, 2014 | 11:58 AM
rjohnson442's Avatar
Mr. Johnson
Also if you take the cap off wiggle the shaft back and forth as you pull up to free it.
442craig
Jul 26, 2014 11:08 AM
EightyEightCut
Jan 19, 2014 08:35 PM
Eddie Hansen
Oct 15, 2012 03:37 PM
chris83
Aug 18, 2012 01:47 PM
Chumley
Nov 10, 2006 06:13 PM
