Dropped Condenser screw into distributor.HELP
Old Nov 10, 2019 | 10:09 AM
64F-85Tom's Avatar
Angry Dropped Condenser screw into distributor.HELP
HI All. Hate to look like a dummy, but I need some help. I've managed to drop one of the condenser screws into the distributor. I probably shouldn't have been trying to do anything with a bad back, but I'm a typical stupid man. Is there any easy way to retrieve the screw from the distributor body without pulling the distributor on my '64 330? There's gotta be a way....
Thanks for the help and not laughing too loudly
Old Nov 10, 2019 | 10:22 AM
Mark the rotor position and pull the distributor, turn it upside down and try and shake it out.
Old Nov 10, 2019 | 10:55 AM
Sugar Bear's Avatar
Try to locate it by eye, bend something like a brake tube or coat hanger, put something on the end of the tube/wire such as strip caulk or thick grease to grab it OR...like oldcutlass suggested pull the distributor. May be able to shop vac it out using tubing to step-down the size of the hose.
Good luck!!!
Old Nov 10, 2019 | 12:47 PM
boese1978's Avatar
Magnet.
pappyl
Sep 8, 2015 09:30 PM
Patrick Samuels
Jul 1, 2014 03:51 AM
Tim305
Apr 26, 2014 11:58 AM
Joah_from_Alberta
Jun 9, 2013 03:12 PM
papas88
Aug 28, 2010 08:15 AM
