1973 350 2BBL Choke Heater Tubes
Old Oct 15, 2019 | 09:30 AM
PowerToTheMaxx's Avatar
Does anyone know where I can buy choke heater tubes for a 73 350 2BBL? Apparently the choke stove location changed from 72 to 73, all the parts I've found online are for 72 and before. I'm not sure but I think the Big Block 2BBL had a different choke stove location on the manifold also.
I know fabricating my own is a possibility, I'm looking into that but seems like a relatively simple part. Anyone have experience with this?
I know converting to electric choke is an option, but Id like to stick with the hot air choke if possible. It seems to be a much more elegant solution, seems how it's actually based on engine heat not just a delay after the engine is started.
Old Oct 15, 2019 | 01:01 PM
You can go to the auto parts store and get a Dorman kit to repair the choke stove. Check it out!
https://www.dormanproducts.com/p-20576-76850.aspx
Old Oct 15, 2019 | 03:47 PM
The factory part numbers for those tubes are the same for 1970-1973. The repro houses don't list past 1972 because in the restoration world there is no market for the 73-77 cars. The 1972 tubes will fit just fine on a 73.
Old Oct 28, 2019 | 02:29 PM
Sorry for the long delay in responding.
I ordered a set of choke tubes from Fusick (PN CTB69/02) listed as "Choke Tubes, pair, late 1969-72 Cutlass 2 barrel v8"
They were very different from the factory ones I pulled off the manifold. I did verify that the manifold is the correct casting for '73.
Maybe Fusick sent the wrong part or the part is inaccurate?
Also, I tried the Dorman one, I couldnt bend it to save my life. The slightest bend and it would kink and break, when I tried by hand or with a hand-held bender. Very annoying.
Old Oct 28, 2019 | 03:36 PM
Try ILT
http://online.flipbuilder.com/wmmk/nfjp/#p=80
Old Oct 29, 2019 | 06:18 AM
That's a bummer.
Hopefully you have better luck with ILT.
Old Nov 4, 2019 | 06:21 PM
Hopefully. Just put it away for the winter . Will try ILT next spring unless I come up with something better
Thanks for all the responses!
ELECMAN
Mar 12, 2024 11:45 AM
rocketraider
Jan 18, 2018 02:36 PM
oldolds88
Feb 5, 2017 07:38 PM
Pfiffle
Dec 14, 2016 03:39 PM
Margie's68
Aug 29, 2007 02:28 PM
