Polyurethane engine mounts?
Old Nov 25, 2019 | 05:41 PM
oldsmoboogie's Avatar
I have searched summit and energy suspension for engine mounts with no luck. Is anyone making polyurethane engine mounts for a 72 cutlass?
Old Nov 25, 2019 | 06:37 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Not to my knowledge. We've discussed this here a while back do a search.
Old Nov 25, 2019 | 07:50 PM
70W-32's Avatar
not enough demand, unfortunately
Old Nov 25, 2019 | 08:36 PM
Mr Nick's Avatar
A few years ago I emailed a few potential suppliers (Energy Suspension, PST...) and nobody even replied.
Old Nov 25, 2019 | 10:35 PM
No one makes poly mounts for your car. Rocket racing makes a solid engine mount that you can mount on the drivers side and run a rubber on the passenger side.
https://shop.rocketracingshop.com/RO...OTOR-MOUNT.htm
Old Nov 26, 2019 | 10:06 AM
brownbomber77's Avatar
Send a grade 8 bolt through the stock motor mount
Old Nov 26, 2019 | 01:21 PM
Funkwagon455's Avatar
If I were concerned about engine movement I’d likely run a torque chain/cable. Solid mounts would not be friendly to the frame.
Last edited by Funkwagon455; Nov 26, 2019 at 02:41 PM. Reason: Auto-spell correction
Old Nov 26, 2019 | 02:38 PM
Yellowstatue's Avatar
Originally Posted by Funkwagon455
If I were concerned about engine movement I’d like run a torque chain/cable. Solid mounts would not be friendly to the frame.
GM had a cable in the early 60's for those vehicles with solid throttle rods. Solved the problem of broken mount jamming the rod at speed.
Old Nov 26, 2019 | 02:44 PM
OLDSter Ralph's Avatar
X 2 with washers on each end
Old Nov 26, 2019 | 02:47 PM
Oldsmobile had one front mount in the middle beneath the harmonic balancer and this was a "quick fix".
Jolly Green
Aug 3, 2015 07:30 AM
Old Olds Fan
Apr 30, 2015 08:58 PM
1978 Oldsmobile Omega
Aug 11, 2014 06:35 PM
getawaycar
May 19, 2011 11:38 PM
jo75olds
Apr 25, 2011 07:51 AM
