Balancer timing mark position 1970 350?
Old Jun 25, 2019 | 04:29 PM
kiloman_11's Avatar
What should the timing mark to crank keyway position be on a 1970 350? This is what mine looks like currently. Is it correct or has it slipped? Thanks
Old Jun 25, 2019 | 09:05 PM
edzolz's Avatar
Doesn't appear to have slipped, but... The best way would be to install it on an engine where you can actually see where TDC is on number one piston. The mark should line up with your timing marker for zero degrees. If not it has slipped.
Old Jun 25, 2019 | 10:04 PM
kiloman_11's Avatar
Good idea. I hadn't gotten that far in assembly yet but I'll see what it looks like. I had heard people talk about how on different years the mark should be in a certain position in relation to the keyway. So hopefully someone has an answer for that.
Old Jun 26, 2019 | 04:21 AM
BillK's Avatar
I have a brand new damper here for a balance job and it looks like the mark is in the same spot as yours.
Old Jun 26, 2019 | 11:01 AM
1964 is the only year that's different, due to the one-year-only water pump with the inlet on the driver's side. The timing tab for 1964 330 motors is on the passenger side, and the balancer mark is different as a result. Of course, for ANY build, you should verify that the balancer mark really does indicate TDC by using a piston stop. Production tolerances do add up.
razman427
Nov 3, 2018 03:55 PM
Mr Shifty Sidney
Jul 6, 2014 07:10 PM
Lars
Dec 3, 2013 03:08 PM
tgilligan
May 8, 2013 03:54 PM
MDchanic
Jul 18, 2011 08:49 PM
