Head Gasket Sealant
Head Gasket Sealant
The manual calls for 1050026 sealant on the head gasket. I don't have that. Is there anything I can get at an auto parts store that works like it, like high tack, shellac, some kind of RTV...?
I use K&W Koppercoat with steel shim gaskets, including intakes (RTV at water ports on intake gaskets). I have heard both ways on Cometic head gaskets--K&W vs. nothing. All assumes good flat surfaces. It is relatively easy to get the intake and exhaust surfaces re-done because they are at 90 degrees from the main surface. It is also good to do the intake surfaces. I don't do them every time, but after 40-50 years, the iron has taken a set and after surfacing should hopefully stay stable.
I am going to repeat what the others have said. No sealer on the blue Fel Pro gaskets. The blue coating actually is a sealer that is meant to "heat flow" and help seal the gasket. If you put something else on it you might actually make it worse
