1964 330ci oil pump
Old Jun 26, 2019 | 06:36 AM
Onit's Avatar
1964 330ci oil pump
Any recommendation on replacement pump?
Melling standard pressure pump work well?
Is the pick up bolt on or press/pin type? I dont have pan off yet.
I am hesitant to replace anyway. It holds 15-20 psi at idle operating temp. But I feel like i should since Im there.
Engine is all stock 290hp 330 with 80k mi.
I pulled it for cam, timing, valve spring, lifter and gasket refresh.
Thank you.
virtualwsp
Oct 10, 2023 06:08 PM
jmos4
Jun 19, 2016 08:15 PM
Rocketbrian
Jan 2, 2015 09:45 AM
Redog
Jul 25, 2011 12:03 PM
Redog
Oct 8, 2010 02:57 PM
