330 Roller Cam & Rockers
Hello everyone,
I recently wiped a lobe or two on my 330 and was looking into upgrading to a roller cam setup. I searched and couldn't find too much on here for the 330. Pretty sure mine is a 67 block and has the #4 heads.
I was looking on mondellos site and I like the specs of this camshaft for street use ->
RH-6-14 Hydraulic Roller Camshaft
$459.00
I understand that the 330 may have specific valve train components and this might be an issue. Maybe someone could point me in the right direction? Thanks.
$459.00
- Muscle Car Performance Cam, 800-4500 RPM Range
- 0.510 Intake lift /0.520 Exhaust Lift
- 252° Advertised Intake Duration / 265° Advertised Exhaust Duration
- 206° Intake Duration @ .050 /214° Exhaust Duration @ .050
- 110° Lobe Separation
AH, that "Mondello", I see that now, I didn't click on the link before because my computer is running slow. Avoid the "Mondello" in Pasa Robles like a plague !!!!!!!!!!! Cutlassefi can certainly help you better !!!!!!!!!!!!!!!
..........Just my two cents worth.
From the research I've done so far..
394417 casting number = '66-'67 330 engine with 39° cam bank angle
Could anyone else with more knowledge confirm this? I plan on getting the parts soon. Thanks in advance!!!
