330 Roller Cam & Rockers
Old May 27, 2019 | 07:17 AM
Alex Melucci's Avatar
76Omega
Hello everyone,
I recently wiped a lobe or two on my 330 and was looking into upgrading to a roller cam setup. I searched and couldn't find too much on here for the 330. Pretty sure mine is a 67 block and has the #4 heads.
I was looking on mondellos site and I like the specs of this camshaft for street use ->
RH-6-14 Hydraulic Roller Camshaft
$459.00
  • Muscle Car Performance Cam, 800-4500 RPM Range
  • 0.510 Intake lift /0.520 Exhaust Lift
  • 252° Advertised Intake Duration / 265° Advertised Exhaust Duration
  • 206° Intake Duration @ .050 /214° Exhaust Duration @ .050
  • 110° Lobe Separation
Everything looks pretty straight forward on their site, until the lifters that are recommended for that cam shaft say "This roller tappet is .500″ longer than a stock tappet and requires a shorter, specially made pushrod" but there is no recommendation.
I understand that the 330 may have specific valve train components and this might be an issue. Maybe someone could point me in the right direction? Thanks.
Old May 27, 2019 | 10:17 AM
cutlassefi's Avatar
Make sure it’s a ‘67 first. Then run the other way from from Mondello in Paso Robles.
I can get you anything you need to do the swap, happy to help.
Old May 27, 2019 | 10:23 AM
OLDSter Ralph's Avatar
Which "Mondello" site are you referring to ? There is a difference !!!!!!!!!!!!!
Old May 27, 2019 | 10:51 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
His link is to Lynn the thief.
Old May 27, 2019 | 11:07 AM
AH, that "Mondello", I see that now, I didn't click on the link before because my computer is running slow. Avoid the "Mondello" in Pasa Robles like a plague !!!!!!!!!!! Cutlassefi can certainly help you better !!!!!!!!!!!!!!!
..........Just my two cents worth.
Old May 27, 2019 | 02:38 PM
76Omega
Thats really good to know! Here are a couple pictures of the block and head casting numbers. Looks like a '67. Thanks!
Old May 30, 2019 | 06:57 AM
brownbomber77's Avatar
Yep, talk to Mark (Cutlass EFI) and stay far FAR away from Lynn at Mondello in Paso Robles.
Old Jul 13, 2019 | 01:12 PM
76Omega
From the research I've done so far..
394417 casting number = '66-'67 330 engine with 39° cam bank angle
Could anyone else with more knowledge confirm this? I plan on getting the parts soon. Thanks in advance!!!
Kalle
Jun 30, 2017 01:10 PM
vetteman
Feb 15, 2013 04:36 PM
edzolz
May 29, 2012 08:49 PM
64oldsguy
Aug 7, 2011 07:56 AM
1964F85
May 15, 2010 12:59 PM
