View Full Version : Small Blocks
- Finally runs
- 350 overheated now running rough
- strong exhaust at start up from my '71 350
- 350 camshaft
- Oil leak and hesitation.
- Engine Noise?
- Olds 307 Edelbrock carb problem
- by pass hose type ??
- Alternator fitment question.
- Oil dipstick?
- '67 330 stumbles at idle when hot
- Intake oil leak
- Used 403, what should I replace?
- 2bbl Choke Binding?
- Lunati W31 cam
- Metal in the filter
- Saving up money for the old money pit.
- Squash Squish?
- 1960 371 $300
- 403 in a 80's H/O
- New fan clutch
- chasing cold start misfire
- Intake/Exhaust Valve question
- head gaskets for 1977 olds 350?
- Radiator questions
- Planning for a future build for more power
- Gap in header flange
- 1969 ram rod w31 350 motor for sale
- 77-80 350 build?
- puzzled
- Idle rpm question
- Problem with a 403 throttle sticking
- Noisey valvetrain
- Olds 330 a few Carburetor questions
- Water pump replacement choice
- Radiator for 1972 Cutlass 350
- Temperature to high Oil Pressure to low
- OL4B Intake Question and Edelbrock covers
- Can someone tell me what this is?
- Rebuild or replace Engine
- Valve cover and oil pan restoration
- Why so much smoke???
- Ready To Run Distributor Install
- Factory mechanical advance?
- 61 f 85 trouble
- Help me decide my engine build...
- Prime new rebuild
- Injectors
- cruising along and car went kaput, so here................
- new to forum, have a Horsepower question
- I need more cow bell
- It's alive! It's alive!
- benefits from timing on stock motor
- Stock Dual vs. headers question....
- 350 Refresh advice
- 2 bbl trouble
- Carb hiss and overheat 72 olds 350
- rocker arm pivot hold downs
- 1st start procedures
- Carburetor advice.
- First Look 72 350...Thoughts?
- Turning over but not starting
- carb adjustment now worried!!!
- ID my pistons
- Head gasket issues need some input.
- timing chain install question
- 350 engine id ?
- Cam Guru Pick Me a Cam 330
- Vaccuum diagram
- 350 rocket new headers
- Massaging a 403
- tornado 403 firing order?
- Cam bolt question
- Engine build
- 350 exhaust
- 1965 Correct Valve covers
- 69 Cutlass 350 engine temp issue
- Vid of my new engine swap
- cylinder head gasket wrong?
- balancer diameter
- Engine random back fire when warming up and surging
- Couple carb/throttle questions
- Piston ring assambly....confused
- Can anyone identify what this is?
- What can I expect 1974 rocket with #6 heads
- SBO 350 GM educational motor.
- Olds 403 C-heads or #5 heads
- '64 330 head with BG suffix question
- no spark 330
- #5 Head build
- 1973 Cutlass S – Couple of things
- Installing fan shroud in a '70 S......help needed!
- X pipe vs H pipe
- Mechanical advance
- Broken bolt
- Flex plate to torque converter
- Any point in priming?
- '58 371 balancing/ dampner
- Thermostat
- what factory intake manifold can i use on a 330ci?
- 330 cam kit
- Couple questions for a slightly modified 330
- Question regarding engine temperature
- Debugging - '73 Cutlass S w/403
- 455 heads on SBO 350
- 1970 California Cutlass 350 question.
- Pulled my heads, they're cracked.
- Trying to get this 350 dialed in
- Olds 350 specific mild build advise needed
- What's it worth: 1974 350 from H/O, 1971 350 2V, both from junkyard
- Who makes the best Olds Gold engine paint
- Botched up success - RPM Intake install
- 1966 Cutlass 330 high compression dead cylinder
- w090898 head stamp
- Performer RPM Intake bolt #7 - how to remove
- Opinions - Spray Copper on Fel-Pro Head Gaskets, Yea or Nay?
- ´58 371 vacuum check valve
- Massive coolant loss - freeze plug?
- '73, 350
- Total timing (max hp)
- bolts for edelbrock intake swap
- Advice on adding electric fans to existing radiator
- Could this be the vacuum advance?
- Gutting 307 emission control vacuum lines
- Oldsmobile engine builder
- A few wiring, vac connections I am unsure of
- 330 Flush Questions
- molded 403 pcv to carb tube, where?
- SBO Performer RPM intake gasket?
- That cant be good
- Now a stuck distributor
- Need Schooling - Ticking noise and top end
- Carb advice needed
- quadrajet help!
- 307 alternator bracket question
- 69 350 connecting rod spit holes
- I want to add the bite to my Rallye's bark
- timing marks where is TDC?
- 72 350 rebuild ?
- Best way to block off water pump to heater core
- Running wire for HEI
- Need a torque spec
- Rocket or ramrod ?
- Olds 350 Rebuild
- carb issue
- Cam walk?
- Quadrajet choke
- oil pressure sending unit
- Talking cam, heads, pistons advice
- oil to top of engine 371
- Guess that mess
- How to remove a Power Steering Pump Pulley?
- Timing cover seal
- Vacuum issue? Carb issue? I have no idea what is going on
- Is it a 350 or 403?
- Swapping #6 for #5 heads
- Need Header Help
- Replacing the Carburetor
- 20 year old performance built 350 - Great find! (I think)
- Olds 350 back together in 72 Cutlass S
- Distributer won't turn help!!
- changing fuel lines
- speed pro piston clearance?
- Deep engine knock, bearing?
- Picked up a '70 350
- Differences between carb of 307 and 350 engine
- Oil pressure sensor too fat
- Exhaust Tips
- Oil pressure fun.
- Extreme Exhaust on New Engine
- Which Holley for my 350?
- Quick Visual Quiz for the Less-Experienced
- Want to convert to dual exhaust - 71 Cutlass
- German inspection - CO measurement
- What's the secret to removing the distributor?
- Wiped camshaft lobe, options for replacement?
- exhaust header/manifold options for a 64 J88 330
- Which Engine book to buy?
- Help Exhaust backfire
- carb and gas question
- headers for bbo headed 330
- New radiator steel straps
- What is a good cleaner for a intake manifold..
- Choke Issues (Quadrajet)
- bad combo? or BAD combo
- swap v6 to small block 77 Omega
- rebuilt 403/ceramic header start up
- Rebuild or replace 330 in 67 ?
- 73 delta 88 royale engine
- Best fitting and cooling G body radiator
- 2bbl 2 4bbl swap w/2711 intake
- New distributor
- Pulley/bearing/pinging???
- Lead substitutes??
- 2 barrel electric choke woes
- RING GEAR - where to get one?
- pulley bolt pattern
- Special 0.001 over lifters?
- '73 Omega w/ '68 Rocket 350, Q-Jet and stock intake manifold, should I replace?
- 330 Alternator/Regulator
- SBO Guru in the Midwest....NE, KS, IA, SD?
- how to tell if piston rings can be reused
- Tuning/ Upgrade Parts for 1952 303 Engine
- 1973 Oldsmobile Omega, Rocket 350, Rad overflow
- loud explosion out exhaust
- 350 Olds Head Gasket Replacement
- Carb backfiring
- 330 Wont Start
- Looking to get a new carb
- cooling system flush
- intake gaskets
- Dual Exhaust on 307
- 68 442 carb #
- New Engine
- New intake question
- 330 exhaust manifolds
- Fuel pump to Carburetor replacement:
- NASCAR block is in!
- fuel pump
- Cleaning rust on a aluminum intake
- The best oil pressure sensor for the olds 307.
- intakes
- 97 Achieva hard start all temps
- oil pump rebuild? successes/failures
- Water Pump leakage-how to seal?
- 403 headers
- Edelbrock Pro-Flo: What's so special?
- Question about vacuum pump
- Small Block Trouble!
- novice 403 rebuild questions, balancer/antifreeze priming
- Thermostat Housing
- small block dilemma
- Accel Distributor
- Removing A.I.R pump/ 1967 Cutlass?
- Timing cover
- coolant, oil problems.
- Quadrajet 73 vs 73
- BBO "C" Heads on 330
- Lifter tick after oil change
- 69 Cutlass 350 (w/Auto/AC) Radiator Question
- Jegs Intake Manifolds
- 87 olds 442 engine swap
- EGR diagram
- what year motor?
- 307 feels bogged down, burning wire smell
- milling 3A heads?
- dont think im running original engine, so what am i running ??
- Make and weight oil for a 72 350 engine
- block color?
- #6 or #8 Heads
