Carb backfiring
Old Apr 4, 2014 | 07:23 AM
sicky olds's Avatar
NôôB
Carb backfiring
Was putting the engine back together (heads and intake manifold only) and when i went to fire the car up it would sound like its timing was off and the carb would back fire BAD. Only difference that i have done is that i am using a 1" carb spacer so i can get rid of those stupid spacer rings for the HEI setup.
Danny Sarvis (w30post i think his name is on here) says it sounds like a vacuum issue and might be because of that spacer (using the thick gaskets on both sides of the spacer with it). Just looking to see what everyones inputs are that may have dealt with this issue or might have an idea on what it can be.
Sicky
Old Apr 4, 2014 | 07:28 AM
tru-blue 442's Avatar
Old School Olds
Tom, double check your firing order.
Sounds like a crossed wire.
Old Apr 4, 2014 | 07:29 AM
Check your firing order. Make sure the cap not cracked and is sitting flush. If that's correct look at the movement of your rockers and make sure they are all moving about the same amount.
Old Apr 4, 2014 | 07:34 AM
sicky olds's Avatar
NôôB
Firing order is fine, I have a loom and didnt change anything in the Dist. Only changed out one wire on the dist cause the MSD wire slipped off and that is on number 3.
From what i saw on the rockers they seemed to be fine, might have to check that number 6 though to make sure seeming that was why i disassembled the top end. It looked like the valves were fine but if there was something wrong with that could that be a cause of this happening
Old Apr 4, 2014 | 07:37 AM
Old School Olds
So none of the valves were
stuck then? And the pushrods
were fine as well?
Backfiring through the carb, if it's not a wiring or timing issue, is generally valve related.
Old Apr 4, 2014 | 07:44 AM
TripDeuces's Avatar
"Backfiring through the carb, if it's not a wiring or timing issue, is generally valve related."
I have to disagree here. It can also be too much initial ignition lead where the flame travels back up past the intake valve and into the intake causing a backfire through the carb.
Old Apr 4, 2014 | 07:46 AM
Old School Olds
If I have the rockers off anything
I will always give the valves a shot
on top with a rubber mallet just to be
sure none are stuck before reassembly.
Old Apr 4, 2014 | 07:47 AM
sicky olds's Avatar
NôôB
were fine as well?
Not from what i could tell the valves and pushrods were perfect. Nothing inside the pushrods either, still had airways and such
Old Apr 4, 2014 | 07:48 AM
sicky olds's Avatar
NôôB
What do you mean by too much ignition lead?
Old Apr 4, 2014 | 07:52 AM
sicky olds's Avatar
NôôB
Erics PM reminded me of something i should add to this story. I somehow got metal chunks in my cylinder 6 that caused the spark plug to be bent, not sure where the metal came from. Our only guess is that it fell into the carb when i was swapping out the air cleaner on the drivers side and when i gassed it and the secondaries opened it fell in and got ate up. Nothing was in the oil and appeared to only be in the #6 cylinder and in the intake right at cylinder 6 port. But valves still mated with the head properly and the cylinder wall and piston head were great.
TripDeuces's Avatar
Putting too much initial timing into the engine. If your engine calls for for 8* initial timing (on the balancer) and you put 15*, 20* whatever into it you can easily get a backfire not to mention hard starting.
Old Apr 4, 2014 | 07:55 AM
Old School Olds
Ouch! Metal in any cylinder is BAD.
You may try cranking it with the wire off
#6. It will miss, but not backfire if that
is the bad cylinder.
Old Apr 4, 2014 | 07:57 AM
sicky olds's Avatar
NôôB
The initial timing was good when we built the motor.
Tru Blu i will have to try that when i get home to work on it.
Old Apr 4, 2014 | 08:00 AM
TripDeuces's Avatar
How did you set initial timing when you built the engine? Also, how do you know the valves are seating fine in the #6 cylinder? Did you do a compression test on it right after the metal fell into it?
Old Apr 4, 2014 | 08:05 AM
sicky olds's Avatar
NôôB
That was all Danny on that part and i can not remember. But the engine ran great (OldCutlass can verify) before this issue and i daily drove it for over a year.
I just did a visual inspection of the valve and it was flush with the head like the others were.
Old Apr 4, 2014 | 08:10 AM
TripDeuces's Avatar
Would I be correct in assuming then that these problems started after the metal went down the carb?
Old Apr 4, 2014 | 08:11 AM
sicky olds's Avatar
NôôB
That is correct sir.
Old Apr 4, 2014 | 08:13 AM
TripDeuces's Avatar
Kinda narrows it down then doesn't it? I think you found your problem. Take the head off.
sicky olds's Avatar
NôôB
but with the metal in the cylinder even the carb did not backfire like it is doing now.
Old Apr 4, 2014 | 08:17 AM
TripDeuces's Avatar
This whole thread makes me think of this flow chart:
Old Apr 4, 2014 | 08:22 AM
sicky olds's Avatar
NôôB
So your saying i should have just left the metal in the cylinder and just changed out the spark plug?
Dont know why you are calling me a dumb **** for trying to fix my car sir
Old Apr 4, 2014 | 09:08 AM
He wasn't calling you a dumb sh**, he was bringing some humor into it. I did mention timing but should have went into more detail, sorry. Yes, way advanced initial timing can cause backfiring through the carb. If the valve came into contact with what ever that was in the cylinder, it may have bent. A bent valve can be hanging or galling in the valve guide or not sealing 100% on the seat allowing the flame to travel back up the intake.
Old Apr 4, 2014 | 10:33 AM
sicky olds's Avatar
NôôB
I will have to look into that. Hate it that this internet doesnt have a sarcasm button . Just kinda stressed out about this and with the job right now >.<
Old Apr 4, 2014 | 10:43 AM
Yeah, just to agree with the others, just as "2+2=4," "Metal in Intake + Poor Running = Head Comes Off."
Old Apr 4, 2014 | 10:48 AM
sicky olds's Avatar
NôôB
going to pull the #6 and try different gaskets on the carb first as it will be easier. Just really sucks as i dont have the time to put into it as i am moving Very soon....
Old Apr 4, 2014 | 12:56 PM
Old School Olds
Good luck Tom.
Keep us posted.
Old Apr 5, 2014 | 08:15 PM
sicky olds's Avatar
NôôB
Lets bring up that flow chart again cause MAJOR Dumb **** took place lol. Timing was the issue, I unplugged the number 3 on the dist and plugged that wire into the broken wire (#5), which means; 5 was firing when 3 shoulda been and 3 wasnt firing at all....
Car is now running again
Old Apr 5, 2014 | 08:34 PM
Ah, so it was the firing order. Glad it wasn't anything major.
Old Apr 6, 2014 | 04:14 AM
Well, without the "Poor Running" part of the equation, the "Head Comes Off" part no longer follows.
Glad you figured it out!
Old Apr 6, 2014 | 05:58 AM
  #31
Old School Olds
Glad to hear you figured it out.
Now back to happy motoring.
Old Apr 6, 2014 | 10:18 AM
  #32
TripDeuces's Avatar
Glad it's fixed
shaks 442 clone
Jan 16, 2014 06:40 PM
cutlassclay
Jan 16, 2014 03:24 AM
84oldsDelta88
Mar 15, 2012 09:29 AM
Wyze
Apr 3, 2010 06:29 AM
cts-v
Jun 18, 2009 08:05 AM
