2bbl 2 4bbl swap w/2711 intake
Ok I've read all the threads I can find on co about swapping out my 69 cutlass 2bbl for a 4bbl. I've searched you tube for video (some are really funny). I decided to go with the edelbrock 2711 intake and the stock quadra jet. I diagramed my 2bbl set up and photographed every inch of where everything goes. I photographed my edelbrock intake printed the photo and labeled where everything should attach on it. My question is where does the PVC hose go on the edelbrock? On my 2 bbl it goes in the back of the carb. On the Qjet 4bbl there is no connection for it. I'm thinking the only place it can go is up front on the intake
but not sure. Also can I fabricate a bracket for an electric choke conversion that can be slipped over the center intake mounting bolts ?
I don't know what you mean by a "bracket" for the electric choke, however.
I thought I could just plug it into any vacuum on the intake but wanted an expert to say so. What I mean by the choke issue is the 69 has a divorced choke that pulls down the butterfly (I know you know that) the new intake has no provision for this. I have seen electric choke conversions that have the electric heating element that bolts to the intake an then connects to the butterfly. The edelbrock has nothing to bolt this too. I was thinking I could make a bracket for this then bolt it to the center intake bolt when I install it but I'm kinda worried I may cause a leak if I do this.
A later Qjet with the integral choke housing would fix this. Just block off the vacuum port inside and add an electric choke coil. I hate manual choke but have at it, if you can live with it.
I considered that approach but from these threads I saw the newer carbs were tuned and set up different and I don't have the skills to mess with it. At this point I already have a rebuilt 69 carb. I hear what you are saying and agree but I don't think the hand choke will be that big a deal.
When i did my 2-4 bbl swap on my 330, this is the edlebrock manifold i was sold.i have not seen anyone use the number 3711.
For a long, long time the 3711 Performer 350 and the 7111 Performer RPM were the only choices. I don't know when the 2711 non-EGR manifold was introduced.
I will never ever install a turkey pan gasket again. Got the intake on . What a pain. I will finish the swap tomorrow. If it leaks I will retry but not with another valley pan.
Some of those valley pans dont line up correctly. The tabs dont go in exactly like they should. It's best to do a dry fit first. Once you get all the tabs in the holes its not bad. What problems did you have?
electra483
September 30th, 2012 04:20 PM
