2bbl 2 4bbl swap w/2711 intake
Old April 13th, 2014, 06:26 AM
1969 cutlass convertible
Tim305's Avatar
Ok I've read all the threads I can find on co about swapping out my 69 cutlass 2bbl for a 4bbl. I've searched you tube for video (some are really funny). I decided to go with the edelbrock 2711 intake and the stock quadra jet. I diagramed my 2bbl set up and photographed every inch of where everything goes. I photographed my edelbrock intake printed the photo and labeled where everything should attach on it. My question is where does the PVC hose go on the edelbrock? On my 2 bbl it goes in the back of the carb. On the Qjet 4bbl there is no connection for it. I'm thinking the only place it can go is up front on the intake
but not sure. Also can I fabricate a bracket for an electric choke conversion that can be slipped over the center intake mounting bolts ?
Tim305 is offline
Old April 13th, 2014, 06:50 AM
Hookers under Hood
76olds's Avatar
My PCV hose went to the front of the carb on my original Quad, also the same as the edelbrock in between the two idle mixture screws, although the 69 4bbl carbs may be different.
76olds is offline
Old April 13th, 2014, 07:46 AM
OK, the first thing is don't over think this. The PCV simply needs to be hooked up to a manifold vacuum port. Doesn't matter if it's in the front of the carb, back of the carb, or a manifold runner. So long as it's straight manifold vacuum, it will work fine.
I don't know what you mean by a "bracket" for the electric choke, however.
joe_padavano is offline
Old April 13th, 2014, 07:56 AM
Tim305's Avatar
I thought I could just plug it into any vacuum on the intake but wanted an expert to say so. What I mean by the choke issue is the 69 has a divorced choke that pulls down the butterfly (I know you know that) the new intake has no provision for this. I have seen electric choke conversions that have the electric heating element that bolts to the intake an then connects to the butterfly. The edelbrock has nothing to bolt this too. I was thinking I could make a bracket for this then bolt it to the center intake bolt when I install it but I'm kinda worried I may cause a leak if I do this.
Tim305 is offline
Old April 13th, 2014, 08:14 AM
I thought that might be what you meant. You probably know that the divorced choke electric conversion kit is supposed to bolt to the pocket on the stock intake. I don't know if you can get the conversion choke in the right place on the E-brock intake with a bracket, but if you can, that would be great. Putting the bracket under the bolt heads on the intake-to-head bolts is no different than putting a washer there, so don't worry about that.
Old April 13th, 2014, 08:34 AM
Tim305's Avatar
Thanks a lot for the help, I think now I'm ready to do this. I think I'll just go with a manual choke.
Tim305 is offline
Old April 13th, 2014, 09:40 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
A later Qjet with the integral choke housing would fix this. Just block off the vacuum port inside and add an electric choke coil. I hate manual choke but have at it, if you can live with it.
olds 307 and 403 is offline
Old April 13th, 2014, 11:12 AM
Tim305's Avatar
I considered that approach but from these threads I saw the newer carbs were tuned and set up different and I don't have the skills to mess with it. At this point I already have a rebuilt 69 carb. I hear what you are saying and agree but I don't think the hand choke will be that big a deal.
Tim305 is offline
Old April 14th, 2014, 04:11 PM
88jetstar's Avatar
When i did my 2-4 bbl swap on my 330, this is the edlebrock manifold i was sold.i have not seen anyone use the number 3711.
88jetstar is offline
Old April 14th, 2014, 04:58 PM
Tim305's Avatar
yea that one would work on mine too but it has blockoffs that are for 19
72 and newer that i did not want to deal with. ps nice ride you got there.
Tim305 is offline
Old April 14th, 2014, 05:29 PM
88jetstar's Avatar
Thanks, yeah I had no idea what the different number was for lol. Now i do
Old April 15th, 2014, 04:27 PM
jag1886's Avatar
If you guys would get over your Holley phobias you could just bolt a 9834 on, everything thing hooks up very easy and it works perfect out of the box on most stock engines.
jag1886 is offline
Old April 16th, 2014, 07:33 AM
88jetstar's Avatar
I used a demon carb on my 330
Old April 16th, 2014, 12:56 PM
Tim305's Avatar
I got no problem with a holly had plenty in past cars. I just like the configuration on the quad. I am sure I can fabricate an electric choke set up.
Tim305 is offline
Old April 16th, 2014, 02:53 PM
69ishHoliday's Avatar
Mine is a 3711 that was practically given to me or I would have chosen either the 2711 or RPM model. - Steven
69ishHoliday is offline
Old April 16th, 2014, 03:35 PM
For a long, long time the 3711 Performer 350 and the 7111 Performer RPM were the only choices. I don't know when the 2711 non-EGR manifold was introduced.
Fun71 is online now
Old April 25th, 2014, 12:54 PM
Tim305's Avatar
I will never ever install a turkey pan gasket again. Got the intake on . What a pain. I will finish the swap tomorrow. If it leaks I will retry but not with another valley pan.
Tim305 is offline
Old April 25th, 2014, 01:06 PM
455man's Avatar
Some of those valley pans dont line up correctly. The tabs dont go in exactly like they should. It's best to do a dry fit first. Once you get all the tabs in the holes its not bad. What problems did you have?
455man is offline
Old April 25th, 2014, 02:47 PM
Tim305's Avatar
I dry fit it twice but when I set the intake in it it pulled one side down out of alignment every time.
Tim305 is offline
Old April 25th, 2014, 03:37 PM
The Felpro pans snap right in from my experience. I had fun with the Corteco pan I picked up for cheap from Rockauto for the Olds powered 4x4.
Tim305
February 17th, 2014 04:37 PM
electra483
September 30th, 2012 04:20 PM
boese1978
April 23rd, 2012 07:46 AM
|-K|=K
October 1st, 2009 07:37 PM
ent72olds
December 1st, 2008 07:14 PM
Quick Reply: 2bbl 2 4bbl swap w/2711 intake
