Help Exhaust backfire
Old Apr 22, 2014 | 09:17 AM
Babafats's Avatar
1970 cutlass 350 bored .030, lopey cam, cold air intake, 10:25:1 comp, Holley 4150 vacuum secondary 650cfm,
At speeds between 25mph and 45mph if you attempt to hold those speeds to cruise the exhaust lets out a light pop pop pop pop until you wither eacclerate out of it or deaccerate out of it. Timing is a little advance with the 4:11 gears in the back, carb is tuned. any ideas?
Old Apr 22, 2014 | 02:48 PM
76olds's Avatar
Hookers under Hood
What diameter exhaust pipes? Are you sure its not popping out the carb ?
Old Apr 23, 2014 | 11:31 AM
Babafats's Avatar
3 inch, no defintly the exhaust and ive tried exhaut leak and new gaskets all the way to the collectors from the headers, ive tuned the carb best i can and the timing is as good as i think it can get.
Old Apr 23, 2014 | 03:28 PM
It could be too much timing. My car is quiet but if I have too much timing it sort of bucks or hunts at a steady low load cruise. I'm not a expert but it would be easy to check.
Old Apr 23, 2014 | 03:55 PM
76olds's Avatar
Hookers under Hood
If your carb is tuned and the timing is ok, maybe you have a loose baffle in one of the mufflers.
nelsontj
Jul 1, 2014 06:16 PM
327supreme
Feb 20, 2009 08:25 AM
D Appeldorn
Sep 19, 2008 03:24 PM
jasoneswan
Mar 4, 2008 09:38 PM
Huron
Jul 14, 2007 09:38 AM
