rocker arm pivot hold downs
Old Jun 25, 2014 | 04:44 PM
s i 442's Avatar
Oldsmobile enthusiast
What in the world is the part number or compatible number?
Jegs has # 077-3236513K looks just like what Olds uses but they say they are for a Jeep?
I tried to get them form Supercars unlimited but they have been back ordered since June 9th and weekly calls just gets me the run around about they will be in tomorrow forgetting I just called last week, so they are out.
Old Jun 25, 2014 | 08:32 PM
s i 442's Avatar
Never mind I figured it out myself as useall.
Tried the useless search option so I wouldn't bother the think heads on here with a question about an Oldsmobile, might as well searched for a spoke tightener it would have been the same results.
Old Jun 25, 2014 | 08:50 PM
Not sure what you're on about, but I wasted my time doing a simple search for you.
O'Reilly's got them for half the price.
Any other questions for Mr. Google?
Old Jun 26, 2014 | 04:51 AM
s i 442's Avatar
Summit had a set of 4, Jegs said they are for Jeep (I called them) Autozone = 0, Our Oreileys had 1 set and back ordered was 2 weeks, old local parts store = 0 but for $14 a piece have by tomorrow, Nothern Auto, good luck with their search.
Old Jun 26, 2014 | 05:22 AM
Weird. A shortage.
Why do you need them - Are yours shot?
Old Jun 26, 2014 | 07:48 AM
s i 442's Avatar
I had two broken aluminum ones so I am changing to the stronger ones.
Old Jun 26, 2014 | 08:03 AM
You can just change the two for now, and do the rest later, or you may be able to buy a few good used ones from a member on here, and replace them later.
Did you try RockAuto?
Old Jun 26, 2014 | 08:17 AM
I'm kinda confused, are you repairing a Jeep or an Olds. Yes the parts look the same.
Old Jun 26, 2014 | 08:58 AM
1970-W30's Avatar
Rock Auto has them for a $1.86 (CLEVITE / PERFECT CIRCLE Part # 2141061
Rocker Arm Pivot OLDSMOBILE ENGINE ALUMINUM) use the discount code for another
5% off........
Old Jun 26, 2014 | 08:59 AM
The AMC 360, as used in the Jeep Grand Wagoneer, among others, has essentially the same rocker pivot setup as the Olds, but the actual parts are different:
(Melling MRM1798 for Olds
MRM 1717 for the AMC
and all of the individual parts are different, except for the center strap, which is th same.
Old Jun 26, 2014 | 09:22 AM
s i 442's Avatar
thats exactly what I saw in comparing them that the stands were a different height.
Old Jun 26, 2014 | 11:40 AM
tru-blue 442's Avatar
Old School Olds
5% off........
Do this and you're there.
Cheap enough for a quality part.
Old Jun 26, 2014 | 11:54 AM
I wonder if the spacing and the bolt mounting holes are the same? If so, then you can mill the Olds setup down to the right height.
atkinsom
Jun 30, 2015 11:40 AM
Cameo White
Aug 5, 2014 09:06 PM
tcarroll
May 20, 2012 01:10 PM
66cv442
May 23, 2009 10:06 AM
65cutty
Apr 10, 2009 04:29 PM
