Headlamp wiring Hold Downs?
Old May 20, 2012 | 08:17 AM
tcarroll's Avatar
This may seem silly but I am not sure what the factory used to hold the headlamp wiring that runs across the top underside of the radiator support over to the passenger headlights on a 1968 Cutlass S. I have ran the wiring according the the manual but the wiring is hanging down along the front top of the radiator. Does anyone know? I really don't want to tie strap it unless it is a last resort. I know later model GM's used a black plastic round hold down that opened up and you run the plastic protective shield through it and snap it back together but I do not believe the 1968 Cutlass had this. Any help is appreciated...Thanks Todd
Old May 20, 2012 | 10:14 AM
rcorrigan5's Avatar
Randy C.
Look at the Fusick on-line catalog (www.fusick.com) for part number 3728. That should solve your problem.
Randy C.
Old May 20, 2012 | 10:52 AM
Todd, What Randy said.
But in all honesty if no one is going to see that because it's covered by the upper rad plate? Why not just use a black plastic zip tie? Basically that's what the repro ones at Fusick and other vendors are, except they 'look original'. If you're doing a full blown concourse resto, go with the vendor ones.
Old May 20, 2012 | 01:10 PM
tcarroll's Avatar
Thanks guys I appreciate it.....Todd
atkinsom
Jun 30, 2015 11:40 AM
Cameo White
Aug 5, 2014 09:06 PM
s i 442
Jun 26, 2014 11:54 AM
kburwell
Sep 30, 2009 04:26 PM
KQQLCAT
Feb 6, 2008 08:37 AM
