Edelbrock Pro-Flo: What's so special?
Old Mar 23, 2014 | 05:59 PM
Keegan's Avatar
http://www.summitracing.com/oh/parts/edl-1002/overview/
I've seen these things installed on several cars at car shows. Last time I was at Summit, I remember seeing a sign below one that advertised something about "100cfm". I'm curious: is there much of a performance gain from these? I mean, they look weird. But I was considering it because I need a new air cleaner. Thanks for the help!
Old Mar 23, 2014 | 06:43 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
Nothing. There are better air filters, the adapter must inhibit flow. Be careful of carb back fires with a foam filter. I burnt mine when I had it, supposedly others have had it catch fire.
Old Mar 23, 2014 | 06:45 PM
coppercutlass's Avatar
Chevy budget Olds powered
I had a pro flo and It caught fire lol albeit it was a huge back fire and the foam may or may not have soaked up starter fluid lol . Im a big fan of the filter tops like the k&n kit or the summit brand kit. They are re usable and look great.
Old Mar 23, 2014 | 07:23 PM
Those are junk, don't buy one. The foam will deteriorate and fall into your carb. I don't even know why they still sell them.
Old Mar 23, 2014 | 08:55 PM
young olds's Avatar
x3 with the fire, it spread to my fire wall and got a little scary. Id never spend money on one.
Old Mar 23, 2014 | 10:24 PM
Keegan's Avatar
Thanks for the info, guys! Definitely not going to get one... Lol!
Old Mar 24, 2014 | 06:06 PM
jag1886's Avatar
Those are CRAP!! They have been crap since day one, I sold those back in the 80's and they where crap then.
Old Mar 24, 2014 | 06:15 PM
Qwik71442's Avatar
Full-time Taxpayer
This^^^^^^^^^^^
Old Mar 24, 2014 | 07:39 PM
Keegan's Avatar
I really love the fact that I'm surrounded by such knowledgeable people. When you're 18 and still starting out with all this, it really helps. Thanks everyone!
Old Mar 24, 2014 | 07:50 PM
teknik22's Avatar
I got the round chrome one for my 77 98 and it made it have more throttle response I saw those ones too but like everybody said I don't trust those foam ones I don't even use them on my imports
Old Mar 24, 2014 | 07:57 PM
This is the way to go if you want a flow through top.
Old Mar 25, 2014 | 01:45 PM
jpc647's Avatar
Do these actually make a difference?
Old Mar 25, 2014 | 03:12 PM
Mr Nick's Avatar
High RPM big motors, I'm sure they help. If you have limited hood clearance and have to run a short 2" filter, a filtered top will help there for sure.
I've never seen any testing, but I would think some air flowing down from the top would help get a cleaner "signal" into the carb, rather than the air flowing from the side and making a 90* turn down into the carb. Would probably only be noticeable on a well tuned max effort combo.
Old Mar 25, 2014 | 05:01 PM
You know it probably helps to some extent but I bought it because I think the chrome tops are tacky ., much like all the chrome on my engine lol. Somehow I end up with chrome stuff in trades and the kicker is it usually works so I run it lol.
Old Mar 25, 2014 | 06:11 PM
ELY442's Avatar
I got one on my Cutlass because of hood clearance. I dont have any problems with the foam.
Old Mar 25, 2014 | 06:25 PM
z11375ss's Avatar
Senior Moment Member
I use them to light fires when I go camping.
Old Mar 25, 2014 | 07:36 PM
ELY442 - get one of these.
http://www.ss396.com/chevelle/ATE-3907.html
Old Mar 25, 2014 | 10:54 PM
z11375ss's Avatar
X2 on that.
Old Mar 26, 2014 | 06:47 AM
ELY442's Avatar
Englishtown, NJ swap meet is coming up in a couple of weeks. I'll be looking for one.
I have basically the same set up as copper, mine is a drop base that I to clearance for the Qjet's secondary air door. I plan on running a 1" spacer with my RPM intake and use an oval air cleaner to tuck inside my scoop, probably the expensive Edelbrock to match my valve covers. This is on the 425, so talking the future here. There are many options for compact air cleaners. You can use the Pro flow but your tune needs to be spot on.
Old Mar 26, 2014 | 10:43 AM
Keegan's Avatar
I put a 1'' spacer under my Qjet about a month ago! It seems to changed the power curve a little. Not an extreme upgrade, of course. But still kinda cool.
Old Jan 13, 2022 | 10:58 PM
Kato_77's Avatar
1977 Buick Park Avenue
Hello all, I’m new to the site. I have the old 403 and I bought an Edelbrock pro flow air filter. Do those do anything or am I better off keeping the stock air with the hose and just upgrading to a K&N 14x3” air filter? I just just want mild bolt-ons. Like maybe an Advance Curve kit, 2.5” Dual exhaust, maybe remove the cat and headers. What do you all think? I don’t want to get too crazy. What I say now, right?! Lol
TIA
Old Jan 14, 2022 | 04:12 AM
Rallye469's Avatar
This is a good watch…
That one you mentioned is among the worst!
https://www.dailymotion.com/video/x693421
-peter
Old Jan 14, 2022 | 06:35 AM
oddball's Avatar
TIA
The comments above are correct - the foam in those filters have a tendency to fall apart and they easily catch fire whenever there's a backfire.
You won't see any improvements from changing an air filter. You can run a K&N if you want, but I'd recommend spending money elsewhere first. Also remember that *cold* air is important. The engine can only breathe so much, so you don't need a gigantic open element.
Old Jan 14, 2022 | 08:13 AM
Kato_77's Avatar
Thank you Oddball and Ralley469
I will return it.
Old Jan 14, 2022 | 08:48 AM
The dual exhaust is a good first mod. Headers can be a PIA but do add power. Make a dual snorkel out of your single snorkel air cleaner, I did. I combined a 307 4bbl air cleaner with a 260 scoop as the second. It looks a lot like a factory dual snorkel with the one small and large dual snorkel. Great part about making one is cost and you can position the second snorkel exactly where you want it to clear accessories. Good luck.
Old Jan 15, 2022 | 01:26 PM
Kato_77's Avatar
Out of line,
thank you for the input. I may go with the dual exhaust first. Maybe instead of doing any mods. I may look for a 455 and swap that engine instead!
Old Jan 15, 2022 | 06:21 PM
Yeah, a 455 is a good idea in full size. You can use the better W/Z manifolds and not deal with headers as well. The passenger side manifold is different on your later 403 vs earlier 330/350 manifolds and 455 W/Z manifolds which all the direct down pipes are made for. Good luck.
Old Jan 16, 2022 | 12:14 PM
Kato_77's Avatar
Thanx, I have so many ideas and not enough money and time. All in that order lol.
stupid question what is the w/z? Learning terminology. It’s definitely different working on my little Honda Civic. Lol
Old Jan 16, 2022 | 04:17 PM
Our family got our first Olds powered car in 1986, a 75 Cutlass 4 door with an Olds 350. I started working on on our 81 Delta 88 4 dr with an Olds 307 at 16 yrs old a few years after we got it in 1990. You will find many others here with a lifelong love of the Oldsmobile V8 and these cars. These are the larger and divided W/Z manifolds that only fit the 400 through 455 BBO.
Old Jan 16, 2022 | 06:50 PM
  #31
Kato_77's Avatar
very cool, thanx!
Human
Dec 10, 2022 07:04 AM
76olds
Aug 26, 2016 08:56 AM
sammy
Feb 11, 2015 12:44 PM
bcf102
May 13, 2014 08:59 PM
RetroRanger
Aug 12, 2011 09:46 AM
