I need more cow bell
Old Jun 28, 2014 | 05:03 PM
jayomega's Avatar
So I just got a 76 omega couple hatchback and im not very happy with the 260 with about 175 hp at best, but the motor only has 46000 original miles. So my question is there away i can give it a little more pony power without breaking the bank?
Old Jun 28, 2014 | 05:07 PM
coppercutlass's Avatar
Chevy budget Olds powered
i'll tell you what everyone else will. Ditch the 260 and buy a 350 . You can find a decent running 350 from time to time and atleast with the 350 you have room for growth.
Old Jun 28, 2014 | 05:14 PM
Octania's Avatar
350 is a drop in, easy as dirt, swap. Instant 2x the power.
Old Jun 28, 2014 | 05:20 PM
jayomega's Avatar
If I put a 350 chevy in it will it bolt right up or will I need to change the housing?
Old Jun 28, 2014 | 06:13 PM
2blu442's Avatar
An Olds 350 will be easy. A chevy 350 can be done but you'll be changing some things. Unless its a multi bolt pattern most automatic transmissions will not interchange between the Chevy and Buick/Olds/Pontiac (BOP). You'll also need to swap out the engine mounts and change some wiring as the starter is on the opposite side. Your call, but in my part of the country you can pick up a 1968-76 Olds 350 motor at a pretty reasonable price. I'd keep it simple and stay Oldsmobile.
John
Old Jun 28, 2014 | 06:17 PM
jayomega's Avatar
Thanks there Jonny
Old Jun 29, 2014 | 01:46 AM
Kennybill's Avatar
Nitrous! Just kidding. I would look for a Oldsmobile 403. Torque is what you want. It is the same outside dimensions as your 260 so it's a bolt in upgrade. Jmo, Ken
Old Jun 29, 2014 | 12:02 PM
DoubleV's Avatar
Here's some bummer info for ya; stock they were only rated at 105 hp.
IMO, your best bet is an OLDS 350 or 403. Chevy into Olds swaps are for losers....
Old Jun 29, 2014 | 01:14 PM
brownbomber77's Avatar
Fo realz...I used to have a 260...no amount of NO2 can make that motor go fast...well...maybe briefly...before you Brian Spillner the hell outta the motor and then the mad scientist and Toretto have to tear apart the block and replace the piston rings ya fried.... Anyway, find a 350 or 403, bolt right in and will make you happy.
Alb
May 13, 2013 05:06 AM
PrimeMinister
Jun 30, 2012 12:58 PM
tessie
Apr 4, 2011 04:50 AM
Keener
Apr 24, 2010 10:43 AM
dan2286
Jul 26, 2008 05:00 PM
