timing marks where is TDC?
this is what i have and this is what the book shows i should have. can anyone tell me what mark do i set it at?
[ATTACH]IMG_0931.jpg[/ATTACH]
you must have this manual memorized. i looked through the entire tune up section and only found the picture i posted. after seeing the one you posted i felt so bad for not finding it i scanned the entire manual and guess what? i still didn't find it. thanks for your help.
While I agree that the manual is a necessity, you don't need it to answer this question. Just LOOK at the timing tab:
The punched hole on the RH side is an "0", as in zero degrees.
The two punched holes on the LH side are a "1" and a "0". as in ten degrees.
I agree with that. I was just looking for what I saw in the manual. To me it looked like holes and notches. My block casting numbers are 395558 2 with number 5 heads. I can't read the engine vin number. I thought it was a correct 69.
The timing marks differ of course between the tiny ringless hub-only balancer as used on 2-bbl 330's and VIN-Y 307's... and the larger OD damper-balancers used on real engines.
[dons asbestos underwear for the ensuing flame war pertaining to how a 330 2-bbl is not a "real engine"]
