timing chain install question
Old Jun 19, 2014 | 08:12 PM
s i 442's Avatar
Oldsmobile enthusiast
When the timing chain and gears are installed on "0" and I put the two dots together, where is the #1 piston supposed to be, all the way up or about 3/4 down in the bore?
Old Jun 19, 2014 | 08:20 PM
Macadoo's Avatar
Okay, let's see if I remember.
O to O should put the #1 cylinder at TDC on the exhaust stroke. But that's how you want to install it. Just know that it's exhaust and not compression when stabbing the dizzy.
Old Jun 19, 2014 | 08:29 PM
Mac is entirely correct, but I would ask: What do you mean, "¾ of the way in the bore"?
Old Jun 19, 2014 | 08:33 PM
s i 442's Avatar
The longer i sit and think about it im pretty sure I lined up the wrong things because I used the "0" at the key way which was strait up and im sure it should have been pointing at about 2 o clock and that would made the piston TDC.
Old Jun 19, 2014 | 08:35 PM
Yes, the crank key points at about 1:30 when the sprocket alignment mark is at 12:00.
That's why I recommend taking a photo of the timing gears before you button it up - saves guesswork later when your memory starts to get shaky.
Old Jun 19, 2014 | 08:54 PM
Macadoo's Avatar
Photo coming up.....
Old Jun 19, 2014 | 08:56 PM
TripDeuces's Avatar
You can put it at mark to mark or 12 o'clock for each, doesn't matter
Macadoo's Avatar
Maybe this will help?
[IMG][/IMG]
Old Jun 19, 2014 | 09:27 PM
Macadoo's Avatar
If you used the Edelbrock double roller it has "advanced" keyways as well as the O to O keyway. I think the others were marked R and A? It's recommended to use the O keyway.
Old Jun 20, 2014 | 12:12 AM
s i 442's Avatar
Yes that is exactly how it should have looked, I must have missed the real "0" and lined up the "0" that was on the key way indicating the "strait up" setting, because now I remember looking at the piston and it was down in the bore and not TDC.
Friday night I'll have to take the front cover back off and fix this!
[IMG][/IMG]
Old Jun 20, 2014 | 07:09 PM
s i 442's Avatar
You should have seen how light the 0 was on the crank sprocket!
I was completely off on lining the dots up! I got it perfect now and back to where i was yesterday at this time plus I cleaned the hole in the bolt head that oils the timing chain, cleaned the oil pump pickup better and just feel alot better about it going back together this time.
Old Jun 20, 2014 | 08:00 PM
cutlassefi's Avatar
That's not really what the term "straight up" means.
I was going to post this this morning, but I had to, y'know, like, go to work and stuff.
I did mine wrong the first time, too - if you look, you can see that there is a "0" right over the keyway on the small sprocket, and an identical "0" in the correct position.
I lined up the wrong one.
Fortunately, I degreed the cam, as one always should, and discovered that it was totally off. I kept looking at it and couldn't figure out what was wrong, then I stepped away for a while and came back and said "Ah ha!"
It's important sometimes to step away, because you can get too involved and miss stuff.
It was easy enough to fix, and of course it was right on when I re-degreed it.
Old Jun 20, 2014 | 09:46 PM
Macadoo's Avatar
That sprocket has a lot of keyways
Old Jun 20, 2014 | 10:08 PM
You can't have too many keyways.
And the super-adjustable one was only a few bucks more than the slightly adjustable one, and you never know when you might need more adjustment...
jaunty75
Nov 1, 2014 10:26 PM
Del70
Aug 31, 2014 06:22 PM
coppercutlass
Aug 5, 2014 01:10 AM
naphtali5725
Mar 6, 2013 09:42 AM
1arunem
Feb 15, 2009 04:48 PM
