timing chain Install 70 350
Old Aug 30, 2014 | 01:27 PM
Del70's Avatar
just want to verify - By design - When the cam timing gear mark is at 6 o'clock and the crank timing gear mark is at the 12 o'clock, then by design the #1 cylinder would be at TDC. thanks
Old Aug 30, 2014 | 02:29 PM
Depending on which stroke, it will either fire #1 or #6.
Old Aug 30, 2014 | 03:59 PM
Octania's Avatar
Look at the cam lobes or
watch the valves or
thumb over spark plug hole feel for compression
Old Aug 30, 2014 | 08:01 PM
Sugar Bear's Avatar
The cam gear dot at 6 o'clock and the crank gear dot at 12 o'clock is cylinder number 1 at TDC on the compression stroke. Both cam lobes will be on the flat side of the cam and the rocker arms on cylinder number 1 will be closed.
When installing the balancer it should line up at 0 degrees if you have not rotated the engine and kept the dots aligned. If it is not zero, the outer ring of the balancer may have slipped/rotated on the inner ring which will cause an inaccurate base ignition timing setting.
Hope this helps.
Old Aug 30, 2014 | 08:04 PM
Smitty275's Avatar
Engine Builder
12 o'clock 12o'clock is #1 tdc on an Olds.
6 & 12 is a Chevy.
Old Aug 30, 2014 | 08:39 PM
6 & 12 is a Chevy.
+1.
Everyone gets this wrong, then wonders why their car won't start.
Old Aug 30, 2014 | 09:10 PM
johnnyjaws's Avatar
when u take the cover off go dot to dot if that's all ur changing and put it back that way ur done
Old Aug 31, 2014 | 02:37 AM
Del70's Avatar
"12 o'clock 12o'clock is #1 tdc on an Olds.
6 & 12 is a Chevy. "
For an olds...if the cam and crank marks are at 12 O'clock and 12 o'clock is #1 at tdc for compression?
if you set the the marks to 6 o'clock for the cam, 12 o'clock for the crank, then should the rotor be pointing to the #6 cylinder?
thanks
Old Aug 31, 2014 | 05:38 AM
Yes and Yes, the rotor should be pointing to the #6 terminal post of the distributor..
Old Aug 31, 2014 | 06:01 AM
Del70's Avatar
thanks Eric -
Old Aug 31, 2014 | 06:08 AM
The firing order is the same whether a Chevy or an Olds. Just the rotation of the distributor is different.
Old Aug 31, 2014 | 07:10 AM
pogo69's Avatar
morgan
you can put the cam dot at 6 and the crank dot at 12 JUST point your dist. to #6
Old Aug 31, 2014 | 08:33 AM
However, that has nothing to do with where the marks are on the gears.
Old Aug 31, 2014 | 06:22 PM
Sugar Bear's Avatar
I apologize for giving incorrect information and say thank you to those who took the time to provide the correction. This will teach me not to rely on memory for a critical application.
P.S. Smitty and Eric not everyone makes this mistake, you knew the answer
deadeyejedi
Aug 14, 2015 09:16 PM
84oldsDelta88
Sep 1, 2014 03:02 PM
s i 442
Jun 20, 2014 10:08 PM
dallasite21
Apr 1, 2010 07:24 PM
dccutlass
Sep 17, 2007 03:08 PM
