PDA
View Full Version : Small Blocks
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 [22] 23 24 25 26 27 28 29 30 31
  1. Water pump lube?..OPinions appreciated
  2. ILT is on crack...
  3. bad cold start
  4. Quadrajet rebuild?
  5. Stock small block rods, differenses
  6. Stupid 260. Stupid DualJet.
  7. 350 Carb Issues
  8. '56 324 carburetor
  9. e4mc quadrajet carb on 1970 olds 350
  10. 68 Cutlass Transmission
  11. Spark plug options for 68 Cutlass 350 Rocket?
  12. Anyone use GRP aluminum rods?
  13. Timing Set Install
  14. moon valve covers
  15. Just bought...I Love my 73 Delta.
  16. 350 SBO Build-Up help
  17. 330 heads on 77 350
  18. Summit Racing Header-Back Dual Exhaust System 680122
  19. SBO BlackJack headers
  20. Engine swap?
  21. 7a heads
  22. I have a dilema
  23. Distributor Problem
  24. curiosity about headers
  25. Push rod oil emission and spinning?
  26. 425 pistons in 350
  27. Dropped oil pan !!
  28. Edelbrock cam....?
  29. 70 Cutlass conv engine and trans question
  30. 330 crank
  31. 215 rocker arm shaft bent and cracked
  32. Who makes rocker studs 3/8" into 7/16" roller rocker
  33. Same ol' schtick...but need opinions!
  34. Engine combo..same ol' question but need help!
  35. 350 small block rebuild/trans question
  36. pcv with non emissions carb?
  37. 71 cutlass 350 starter
  38. 1990 Cutlass Ciera engine question
  39. 1986 307 Wiring mess
  40. 1972 cutlass carb questions??
  41. It's Alive!
  42. Boggs bad from dead stop
  43. Engine attempts to cut off
  44. Brake line routing - around headers
  45. Rochester Quadrajet Question
  46. Help With Cam Selection
  47. 330 steel crank
  48. Vacuum thingee on the firewall
  49. How do I adjust the Slow Idle Solenoid? (2GC)
  50. Having engine sputter
  51. newly rebuilt 350 rocket
  52. 350 heads on 330
  53. Strap and stud kit?
  54. Header collector too "high"?
  55. hmm what is the next step
  56. rocket 350 cam!
  57. Trashed my starter (twice), need some suggestions
  58. 1968 cutlass oil pan
  59. 64 330 engine oiling question
  60. L32 vs L34
  61. Smoke
  62. Weird Acceleration Issue
  63. Engine getting rebuilt
  64. 77-80 350 Web Mains
  65. Back to stock distributor
  66. Comp Cams or Cloyes Timing Set
  67. Help! Quadrajet hookup
  68. HEI advance weights is this right ? pic inside
  69. ERG is gone do I still need to hook up the carb
  70. fuel shooting out the top of my carb
  71. New sylinder heads for 371??
  72. Where to start with tuining carb/ignition
  73. Time for a tune-up - questions
  74. 1968 Olds Cutlass S 350 Engine Rebuild
  75. Washington Olds Machinists/Engine Builders Shop
  76. Flowmaster install problem
  77. Is this set-up OK w pics
  78. 1961 f85 215 v8 head bolt torque
  79. 403/350
  80. Light Blue 350 Rocket motor?
  81. 78 rocket 350 help!!!
  82. Radiator
  83. Wow, I feel stupid
  84. BB Olds heads on 403 build???
  85. Well I pulled 3 plugs out to have a look :/
  86. Small Block True Dual Exhaust Manifolds?
  87. New build startup checks
  88. Rebuilding my hurt 324
  89. Nashville Machine shop/Engine builder??
  90. Rocket rebuild
  91. What heads to use on my 330 #1 or #2 heads
  92. Adjustable vacuum canister issue
  93. Headman very tight fit
  94. 66 330 hp?
  95. Yet another dumb question...
  96. 1972 350 rocket
  97. Connecting rod problems
  98. '72 350 Sanderson Shorty Rear Dump Downpipe
  99. 74 delta 350 headers
  100. oil leak?!?!
  101. Time to buy parts
  102. Tranny strong enough?
  103. Oil pressure sending unit too big
  104. Will a rebuilt engine make self-repair difficult?
  105. Fel Pro Gasket MS960027 fit a 1970 Cutlass Supreme 350
  106. Busted vacuum advance?
  107. Intake Manifold/Carb Interchange
  108. Head Gasket ?
  109. Edelbrock 7111 vs 2711 intake manifold for 350 Rocket?
  110. 4v to 2v Carb Adap Plate. Anyone try this?
  111. Oil Pan Removal 63 F85
  112. Fuel pump to carb line
  113. Noise comming from Flywheel / TC area
  114. 350 Hesitates
  115. Carb size?
  116. Are these two temperature sensors?
  117. Rebuilding 350 rocket '68
  118. Cutty Stumbling.
  119. oil cooler ?????
  120. Getting my engine done.
  121. Engine code 350 68-69
  122. pistons for changing compression '70 350
  123. Pinging under load??
  124. 63 F85 215cid serpentine conversion??
  125. 7111 Intake won't fit - Milling required?
  126. qjet i.d.
  127. Tps problems 1987 olds engine
  128. What would the deck height be?
  129. Oil pan retorquing?
  130. Oil Pump/Pressure In 215
  131. Difference/Quality of Hyd. Roller Lifters (retro-fit)
  132. knocking noise
  133. another Holley tuning thread
  134. rebuild Kit.
  135. 403 rebuild
  136. Any sites/stores with Speed Pro L2321 .30 pistons?
  137. Radiator choices???
  138. What is the correct pulleys?
  139. embarrasing motor issue
  140. Valley Pan sealant
  141. Quadrajet 4MV help please
  142. 350 build questions - C/R etc...
  143. Fan Clutch Spacer?? Need ideas...
  144. Edelbrock 1406 throttle return/bracket modification
  145. Is 2.25 vs 2.5 exhaust that much of a difference?
  146. oil plug gasket?
  147. Rectangle shaped hole above cam olds 350???
  148. 1974 delta 88 350 ROCKET
  149. champion radiators?
  150. Oil pressure range?
  151. Drive belt slippage problem
  152. 330HO ci Spark Plug Gap
  153. Should I put headers on my bone stock 70 Supreme?
  154. 1952 Oldsmobile 303 ? Please Help
  155. Hedman Questions / Supreme Offset
  156. 350 cam selection
  157. 307 wont run
  158. Small Block 307
  159. Firing problems
  160. 64 cutlass oil pan
  161. Take a look at my bottom
  162. What is...this hole?
  163. 52/98 help
  164. Coolant leaking from under dash,,,,,suggestions please
  165. roller rockarms ticking
  166. Fuel pump eccentric missing
  167. distributor conversion
  168. Float adjustment 72 350 Rochester 2GC
  169. 350 rebuild tell me what you guys think!
  170. Motor Overheats/Electric Fan Option?
  171. Should I buy a Diesel 350 converted to gas?
  172. Olds 355 4 bolt main ?
  173. Sanderson Headers
  174. Helpful Hint about Timing Mark Alignment
  175. Lifter angle/camshaft question
  176. 71 cutlass surpreme 350 engine belt routing
  177. New Carb Won't Start 72 350 rocket
  178. Carburetor Referral
  179. Vacuum source for choke pull-off
  180. alternator underdrive pulley
  181. K&N breather for 307
  182. need help with block and manifold number
  183. Edelbrock 1405 to Performer EGR 3711 Clearance
  184. Exhaust systems: manufacturers, sizes and set up??
  185. 1965 jetstar
  186. factory aluminum intake on a 72 smallblock
  187. water in the valley
  188. 215 Question (trans options)
  189. reinstall rockers
  190. Olds 350 Head problem
  191. Uh oh.
  192. no spark
  193. Pulley Tolerances
  194. Safe RPM Limit for 350
  195. Open headers
  196. Poly motor mounts?
  197. 1974 delta 88 350 ROCKET
  198. 72 Cutlass 'S' HEI Re-Curve
  199. edelbrock 3711 doesn't fit
  200. getting the most out of my engine
  201. Carburetor Replacement Question
  202. 1964 cutlass 330 headers
  203. Valve seals and damper springs
  204. rebuild
  205. safe cleaning tricks to rid calcium deposits n radiator...
  206. New build, can't prime
  207. camshaft retaining plate?
  208. carb or distributor ?
  209. ticking in motor, no exsaust in right pipe!?
  210. Guesstimate Compression
  211. Leaking from intake
  212. New cam and roller rocker kit, with old valve springs?
  213. Looking for a good machine shop in the DFW, TX area to rebuild a 403 olds
  214. Fan Shroud for 1970 Supreme
  215. 72 Cutlass Supreme Running Hot in 114F AZ Heat!
  216. Too much lift?
  217. 1964 330 engine
  218. Washer welded over intake bolt hole?
  219. Dumb thermostat question(s)
  220. Valve guide seal replacement - anything special
  221. Drain hole locations for 7A heads?
  222. Timming my 1979 260 engine
  223. valve train noise
  224. who knows of a good OLDS experienced machine shop in Phoenix AZ
  225. Olds 350 misfiring?
  226. Edelbrock 7813 - Edelbrock Performer Link Timing Chain Set
  227. 49 Olds Big Six
  228. calcium deposits in my radiator...please help a damsel in distress
  229. Timing Chain Cover Suggestions Please
  230. Begining of season Set up
  231. 55 Olds 88 Idle or Choke Problem
  232. Headers - Flowtech??
  233. 71 Olds Running hot no matter what..
  234. Header Fitment
  235. Pain in the rear or fairly easy replacement?
  236. 7a head dowels
  237. Inteak help!!
  238. Fan clutch removal issue
  239. not enough air comming thru fan ?
  240. heater control valve help
  241. 403 rebuilding advice
  242. Edelbrock Performer RPM Intake
  243. Motor oil preference
  244. Single to Dual Exhaust Conversion?
  245. large center bolt on 1970 350 crankshaft pulley
  246. Pulley misalignment
  247. Stainless steel valves worth it?
  248. Help...need pictures of 403 engine!
  249. Starters - replace for headers?
  250. SB 350 idles fine in Park, almost dies when put into gear
