350 small block rebuild/trans question
Old Sep 19, 2011 | 04:57 PM
leroycjr's Avatar
I'm rebuilding my engine and using the following upgrades from Summit (below). Would the the stock TH350 transmission still be ok for this set up? I'm not doing anything else to the engine.
Edellbrock
Intake 7111
Performer RPM, Dual Plane, Aluminum, Natural, Square/Spread Bore,
Cam/lifter 7112
Cam and Lifters, Hydraulic Flat Tappet, Advertised Duration 290/300, Lift .496/.520,
Carb 1411
Performer, 750 cfm, 4-Barrel, Square Bore, Electric Choke, Single Inlet,
Timing Chain - Double rolled
Old Sep 19, 2011 | 06:47 PM
coppercutlass's Avatar
Chevy budget Olds powered
the 750 is too much carb i would recommend the 1405 and i would recommend a shift kit and a 2200 stall converter. That cam is kind of generic as well i would go for something that would work with the rear end gears you want to use i run 13.3's and that 600 cfm feeds the engine well and i rev it up to 6k rpm
Old Sep 19, 2011 | 07:20 PM
oldzy's Avatar
Too many unknown variables.
Old Sep 19, 2011 | 08:35 PM
x2 with oldzy what gear are you planing on running what compression etc etc
Old Sep 20, 2011 | 10:36 AM
captjim's Avatar
What pistons are you using?
bocoogto
Aug 26, 2023 06:09 PM
TicTocTach
Feb 19, 2013 05:16 PM
VinMichael
Non-Olds Engines
Oct 22, 2012 05:33 AM
olds4life
Feb 9, 2010 08:48 AM
citcapp
Jan 31, 2009 04:01 PM
