Timing Chain Cover Suggestions Please
Old Jun 22, 2011 | 09:30 AM
70Cutlass_408's Avatar
Is this timing chain cover something I should replace. Im replacing the water pump and my timing cover looks bad to me. Suggestions greatly appreciated. Or am I ok using the existing cover.
thanks.
Old Jun 22, 2011 | 10:46 AM
halfmoontrail's Avatar
thanks.
[Flame suit on] You will be fine using the existing cover, as long as none of the corrosion goes all the way through the cover.
Steve
rocketraider's Avatar
Oldsdruid
You may be able to find a new one or one in better shape. It was used from 1964-1990 on everything from 260 to 455.
If you can't find one, sandblast the water pump side especially paying attention to the pitted areas. If they don't blow thru while you're blasting, you should be OK.
Then mix up a good epoxy and work it into the pits for good adhesion. An epoxy that can be sanded or machined is what you want. Level it down good with a sanding block or nib file, in multiple coats and steps if needed, and check it against a water pump with known true sealing surfaces.
A little work, but beats coolant getting into yer oil.
Old Jun 23, 2011 | 05:37 PM
joesw31's Avatar
Change the timing cover. IMO
Old Jun 23, 2011 | 06:02 PM
442scotty's Avatar
change it...only 65.00 bucks or so for a new one...worth the peace of mind
Old Jun 23, 2011 | 06:17 PM
getawaycar's Avatar
1968 442 restoration
GM part number 22525282. I bought one today from my local Chevy dealer.
Chris
Old Jun 23, 2011 | 07:26 PM
BIGJERR's Avatar
I bleed Oldsmobile
I have reused way worse.........As long as you have it clean when assembled the silcon and gasket will fill in the pits........I have hit them with a D/A for a uniform finish.......Jerr
Old Jun 23, 2011 | 08:28 PM
Looks fine to me - nobody's ever going to see the inside of it behind the water pump.
Just put your engine back together.
Mongoose
Dec 21, 2013 04:24 AM
72OLDS-EH
Jul 5, 2010 05:00 PM
dallasite21
Jun 20, 2010 05:37 AM
crazy'boutOlds
Aug 6, 2009 05:40 AM
sklbndt
Apr 15, 2009 04:34 PM
