1964 330 engine
Old Jun 26, 2011 | 03:07 PM
dartphil's Avatar
1964 330 engine
Hello I am getting ready to buy a 64 olds with the 330 engine. I am not familiar with Olds engines. Will parts interchange with others and who make hi performance parts for them, Thanks Phil
Old Jun 26, 2011 | 06:24 PM
442scotty's Avatar
Never had a 64...lots of 65s over the years...I think thr 64 330 had a shaft style rocker system..went to a different morte modern setup in 65.
Check supercars unlimited for parts/performance ideas
Old Jun 27, 2011 | 07:06 AM
All small block Olds motors are externally identical, so bolt-on parts interchange with those from a 350. Intakes, front cover, timing chain, oil pan and pump, distributor, etc. Cam will depend on the lifter bank angle. Exhaust manifolds need to match the chassis. As noted, the 1964 330s have two major differences from later small block Olds motors. The shaft-mount rockers and #1 heads are one and the driver's side water pump inlet is the other. The water pump inlet difference forces the timing tab to be on the other side of the motor from those on all other 1965-1990 Olds motors and as a result the balancer has a different timing mark location.
belairbob
Aug 15, 2012 07:11 PM
belairbob
May 12, 2012 04:51 AM
real57vetteguy
Nov 8, 2011 07:32 AM
Threejdsolds
Paint
Sep 17, 2011 05:18 PM
