Dropped oil pan !!
Old Sep 23, 2011 | 07:05 PM
jcddyy's Avatar
Dropped oil pan !!
I own a 72 cutlass 4dr 350 rocket. I started leaking oil from around oil pan and with the motor still in the car and 6 hrs later dropped the oil pan to replace gasket. My question is what should I look at since I can look directly into the block? I'm a novice and anxious to learn. So far it looks very clean and found very small amount of shavings. All comments are welcome.
Old Sep 23, 2011 | 07:30 PM
Lady72nRob71's Avatar
Describe the shavings more. Like pixie dust or larger?
Old Sep 23, 2011 | 10:06 PM
Redog's Avatar
Stock pan?
When I removed the stock pan off my 330, it was dented in a few spots. Not enough to hit the crank, but the plug area was pushed up enough that the oil did not completely drain out and there was a fair amount of sluge there.
Also look for any little plastic or metal things that look like this ^ they are parts of the teeth from the timing chain which means the chain needs to be replaced
"pixie" dust type shavings are OK, but if they are bigger, that spells problems.
Look at the oil pump screen, see that it's clear
Old Sep 24, 2011 | 07:46 AM
jcddyy's Avatar
Yeak like pixie dust. The screen is clear and I did find one cylinder shape piece maybe 2mm long
. Other than that big piece no other .. man I should have taken a pic
Old Sep 24, 2011 | 07:50 AM
jcddyy's Avatar
Originally Posted by Redog
Stock pan?
Yeah stock pump. I have a few dents also and no teeth like shavings.. I did find a small cylinder shape piece about 2mm long but thin in width.
Screen is clear.
Overall it looks pretty clean inside the block.
Old Sep 24, 2011 | 08:27 AM
brown7373's Avatar
Metal wears and small shavings and dust like pieces are normal and typical. As with any engine, eventually an engine wears to the point it needs rebuilt. Ad bad sign would be finding larger pieces, ships, chucks broken gear teeth or maybe the kitchen sink. But what you described sounds like normal wear. And remember, you didn't go in there because of an oil leak, not because you heard parts rattling arouind. Oil pans leak because the gasket dries out, the bolts get loose, which can let grot and dirt get onto the loose area of the gasket. That is why just retightening the pan on an old gasket doesn't neccessarily totally stop a pan leak like a clean gasket surface and a new gasket.
Take great care to get the surface as clean as possible, and without any old gasket material left. I might use Permatex on the gasket, but what do you guys think best to coat the new gasket with? Tighten the bolts gradually, criss crossing around the pan and carefully torque them properly, and DO NOT OVER TIGHTEN, which can distort and damage a new gasket. But I would definitely use a torque wrench for the. I think the torque is somewhere around 6 to 8 foot pounds, which takes a small inch pounds torque wrench. Doind it by feel might work well for an experienced mechanic, but for you and me, it is almost impossible to tell the difference between 4 pounds and 14, and that is a HUGE difference. Don't do the work to fix it today to have it leak tomorrow.
Old Sep 24, 2011 | 05:47 PM
jcddyy's Avatar
Ok.. Im done. Thanks for the advice guys. I bought a poly/cork gasket and it had a thin metal layer in the middle of the gasket. I used permatex gasket sealent. Advice for anybody reading this .. Allow sealant to completly dry. Instructions say once the sealant becomes "tacky" it will stay in place.. I went ahead when it was "tacky" and the gasket moved around and eventually came off with all the comotion from installing while motor still in vehicle. I took it off cleaned and did it all again. I took a hair dryer to it to speed up drying . Then went back at it. I have not started it. Since I had to take the 100lb starter I decided to run new wire and ends since the looked thin and fraile. You guys are the best thing a young man like myself can ask for. Thanks
Old Sep 24, 2011 | 06:55 PM
Glad we can help...
Use a nut driver to help avoid overtightening.
Alocatelli
Drivetrain/Differentials
Mar 12, 2009 04:43 AM
moberg
Mar 4, 2009 12:13 AM
Rangerdog
Oct 4, 2008 05:01 PM
Nailhead 88
Jul 28, 2008 02:47 PM
