Headman very tight fit
Old Aug 20, 2011 | 02:06 PM
boondocker's Avatar
Where were you in '72?
Are there any tricks intalling Headman headers with engine in chassis? I don"t see a lot of room, in fact I'm guessing I might have to lift the engine to get them in. These pipes were on this engine originally.
Old Aug 20, 2011 | 02:26 PM
compedgemarine's Avatar
you should be able to do it without lifting the engine. they usually have to go in from the bottom and yes they can be tight getting them in.
Old Aug 20, 2011 | 04:00 PM
jag1886's Avatar
You may have to pull one motor mount bolt and tilt the engine back and forth with a floor jack under the pan.
Old Aug 20, 2011 | 10:26 PM
Steve O's Avatar
As much as we may curse these header manufactures the fact is they usually go right in and out after you pull the oil filter adapter and the starter
When their in there they may look like a nightmare though...
Im impressed with all the work that went into most of my headers to tell ya the truth
Old Aug 21, 2011 | 12:51 PM
boondocker's Avatar
I managed to get them in, removed the oil filter, loosened the trans mounts and raised the engine a few inches. It's an open chassis so the effort isn't a big deal...I suspect removing the starter may have worked as well. Thanks All
Old Aug 22, 2011 | 08:01 AM
Generally in the instructions it says to remove starter and oil filter. Glad to hear you got em in!!
louie
Sep 15, 2013 10:39 AM
italian ice
Apr 23, 2013 02:26 PM
michael hilsabeck
Apr 4, 2011 03:49 PM
gbodyfan
Jun 13, 2010 07:54 PM
