Oil pressure sending unit too big
Old Aug 18, 2011 | 06:36 PM
boondocker's Avatar
Where were you in '72?
Just got my new AutoMeter gauges and my oil 100 pressure sending unit is huge, big enough that it won't fit behind the water pump location. Has anyone encountered this and what is the remedy...different sender?
Old Aug 18, 2011 | 06:41 PM
Originally Posted by boondocker
... what is the remedy...different sender?
Longer piece of pipe, or a 45° angle fitting.
Old Aug 18, 2011 | 07:14 PM
Lady72nRob71's Avatar
The factory used a 45* extension piece...
Old Aug 18, 2011 | 07:17 PM
Funkwagon455's Avatar
I'm pretty sure these are still available though Fusick/Year One/OPG ect.
ozoneblue's Avatar
You are about to become a certified plumber . 1 atta boy
Old Aug 18, 2011 | 07:19 PM
I'm pretty sure they're cheaper at the corner hardware store.
Old Aug 18, 2011 | 07:44 PM
I looked for one there but never found one. I just coughed up the 20 for one at the parts place, and it even fit without modification!
Who said you had to have brains to be a plumber.......
Old Aug 18, 2011 | 08:50 PM
stevengerard's Avatar
yep they make reproductions for it but you can also use the NPT fittings from the hardware store - either will work
Old Aug 19, 2011 | 11:57 AM
boondocker's Avatar
Little funky looking, but should work.
Old Aug 19, 2011 | 12:19 PM
Nothin' funky there - looks great!
Just what I was talking about.
If you really wanted to go nuts, you could always "customize" those fittings with a grinder.
Old Aug 19, 2011 | 12:21 PM
I've never seen galvanized fittings in such a small size..........
BTW, where is your bypass hose?
Old Aug 19, 2011 | 12:32 PM
boondocker's Avatar
Thanks for all the help guys...Rob, my engines still under construction, hope to have it in the chassis this weekend.
Old Aug 21, 2011 | 10:50 PM
64Rocket's Avatar
I would have used brass like the factory.
Gene
Old Aug 22, 2011 | 04:42 AM
Chesrown 67 OAI's Avatar
Gene
X 2 !! Got to auto parts store and get those pipe fittings in BRASS! Makes a much better looking installation! Any NAPA store will have them!!
Old Aug 22, 2011 | 05:02 AM
Never knew Napa had those - great tip!
Old Aug 22, 2011 | 10:03 AM
Redog's Avatar
Home Depot and about $2.
I "T"ed mine because I kept the factory oil light. I used a 1/8 brass fitting from a fuel gauge pod that I had laying around. A double ended (like a striaght pipe with threads) 1/8 male fitting and a 1/8 T fitting.
USE TEFLON TAPE!!!
TheRuss
Sep 30, 2025 05:33 AM
Chris J
Mar 31, 2013 07:09 PM
mmurphy77
Mar 13, 2011 08:08 PM
boese1978
Jan 22, 2008 11:56 AM
