Rocket rebuild
Old Aug 22, 2011 | 07:41 AM
LangfordBoy's Avatar
Rocket rebuild
Hi everyone, i haven't been on here for a while. I have a 350 rocket(gold) out of a 69 holiday coupe. The block(395558) is about to go to the machine shop for a cleaning/honing and a crank turn/ balance. I have a set of 7a heads and 4 barrel holly double pumper. i also have a turbo 350 trans with sift kit and the 13 bolt rearend. I am planning on getting hooker headers/ dual flowmaster exhaust. i"m looking for some help with pistons and cam/lifter. I'm not to sure which one to go with, i want to get the most horse power i can without going to crazy ie. boring out the block. Thanks
Old Aug 22, 2011 | 07:50 AM
Run to Rund's Avatar
W31 forged aftermarket pistons would be stronger and give a bit more compression. Howsever, be sure the block isn't worn or it would be better to bore it and get the pistons .030" over. Don't use too big a Holley or you will get a huge bog when opening the secondaries, especially if you have street gearing. Tell us more about the 13 bolt differential, lol.
Old Aug 22, 2011 | 10:53 AM
cutlassefi's Avatar
There are other options available on pistons i.e. Probe etc.
A double pumper with a 9.5:1 small block and an automatic is not normally a good combo, can you trade for a vacuum secondary?
If you want to hear the cam and make awesome midrange torque then I'd recommend an Erson TQ40.
FYI- there's an article in the newest PHR on a SBF. It can be related to any engine with similar cubic inches and head flow. They did 2 Xtreme profiles and even touted the fast ramp design and features. However it was the slower ramped Thump'r that trumped both the Xtremes. They did a similar test a couple years ago on a mild SBC, same results.
There's someone on here that's been preaching that same line of thinking especially for stock headed V-8's.... hmmm wonder who that might be?
jensenracing77
Jan 12, 2016 02:02 PM
442dreamer
Aug 23, 2011 07:28 AM
Gary's 2 442-S
Aug 14, 2011 12:04 PM
442oldslawyer
Apr 29, 2010 09:22 PM
cutlass tom
Nov 21, 2006 07:09 PM
