1974 delta 88 350 ROCKET
Old Aug 2, 2011 | 06:46 AM
delta254's Avatar
OK finally got it running new plugs wires, radiator, carb rebuilt quadrajet, fuel pump filters, it does have points, the problem Im having is it seems to be missing a bit like the engine shakes to much any suggestions were to start?
Old Aug 2, 2011 | 06:50 AM
citcapp's Avatar
Look to make sure you have the plug wires in the right firing order. The engine shaking usually means you have a wire or two crossed. Common thing when replacing wires
Old Aug 2, 2011 | 07:53 AM
jaunty75's Avatar
Could this possibly be due to a vacuum leak somewhere, too?
Old Aug 2, 2011 | 08:12 AM
Rickman48's Avatar
Any combination of the above including timing, carb settings, or a myraid of problems!
Start w/ correct wires, look for an unplugged/broken vacuum line, set the timing correctly, check the distributor vacuum canister, set the carb w/a vacuum guage, and see what it is.
Most obvious first!
Old Aug 2, 2011 | 08:37 AM
delta254's Avatar
Most obvious first!
im purty sure the wires are not wrong but will double check, maybe vacum lines, plus it takes it 3 to 5 mins to warm up before it idles byitesle without dying any suggest on that.
Old Aug 2, 2011 | 08:42 AM
jaunty75's Avatar
You cannot have just one crossed plug wire. If one is wrong, then at least two are wrong, and this would be a serious issue. You really want to double-check this.
Does the engine miss occur immediately after the car is started and continue no matter how long the engine runs and warms up nor what you rev it to? If so, I do like the idea of crossed wires.
If your engine won't stay running once started from cold but will stay running once warmed up, you could have a problem with the choke or perhaps an improperly set idle speed. I presume you have the tune-up specs for the car and have properly set the dwell, timing, in Park and in Drive idle speeds, and so forth, and that you did all this with the engine fully warmed up?
Old Aug 2, 2011 | 09:45 AM
delta254's Avatar
As soon as the car turns on it wants to die, so we rev it up not sure how much rpms, it takes maybe 3 minutes or so then it idles byself but the engine still shakes and seems like its missing but it runs fine no spits or studers after driving it 15 minutes the engice still shakes but does not dye.
Old Aug 2, 2011 | 12:15 PM
jaunty75's Avatar
You still haven't said if you've actually done a proper tune-up with regard to dwell, timing, idle speed, etc. You also need to make sure the choke is working properly. The fact that your car does not die after warming up but has difficulty staying running when cold suggests a choke problem.
BUT, it could also be improperly set idle speeds. That why you need to do the proper tune-up. There could also be a vacuum leaks.
Check that the plug wires are properly connected.
Do all these things and then get back with us. Until you do, we can't rule anything out, and we end up with are the same suggestions over and over again.
Old Sep 16, 2011 | 08:08 PM
jwf's Avatar
jwf
can you tell me where master cylinder and booster is located on 1957 olds 88
1978 Oldsmobile Omega
Jun 15, 2014 07:23 PM
Hurst/Olds 73/74
May 30, 2014 12:56 PM
1974
May 6, 2012 07:16 AM
delta254
Jul 7, 2011 11:44 AM
Gearhead442
May 16, 2010 09:01 AM
