edelbrock 3711 doesn't fit
Old Jul 6, 2011 | 07:55 AM
wally74's Avatar
Hello all,
Maybe I'm doing something wrong but....
When I try to install my new 3711 on my 350 (1975) it doesn't fit.
I can get the bolts in on one side or the other.... but not on both sides...
HELP
wally
Old Jul 6, 2011 | 08:07 AM
Stattiolds69's Avatar
Question
This might be a dumb question but are you sure it's a 350 olds and not a big block olds, got any pics?
Old Jul 6, 2011 | 09:43 AM
allyolds68's Avatar
Originally Posted by wally74
Hello all,
HELP
wally
Sounds like someone milled the heads
Old Jul 6, 2011 | 10:02 AM
wally74's Avatar
Yo Statti, here's a pic.
I changed the PS head gasket and exhaust man. gasket. so .....?
When I put the old cast iron intake manifold between the heads then it fits......
Old Jul 6, 2011 | 10:07 AM
wally74's Avatar
how can I post a pic?
I tried it with photobucket but not a great result....
wally
Old Jul 6, 2011 | 10:25 AM
Tony72Cutlass'S''s Avatar
click "go advanced" you should have the option to upload a picture, you might have to lower the resolution of the image to the required dimensions though, use microsoft word or something to do that then save the file locally.
-Tony
Old Jul 6, 2011 | 11:00 AM
wally74's Avatar
this time better....
Old Jul 6, 2011 | 03:04 PM
Redog's Avatar
What are the casting numbers between the water pump and the manifold.
The BBO manifold is wider than a SBO
Old Jul 6, 2011 | 04:33 PM
defiant1's Avatar
My 3711 did not fit when I used the end rubber gaskets. My heads were milled .010, but the bolts were not even close to lining up. I used RTV all the way around and I had no problems.
d1
Old Jul 6, 2011 | 04:41 PM
jag1886's Avatar
Take out the rubber end gaskets and silicone the ends. I had the same problem.
Old Jul 7, 2011 | 10:09 AM
coppercutlass's Avatar
Chevy budget Olds powered
Make sure you have the right gaskets I had to get my intake milled 70 thousanths to make up for the .040 taken off the heads
Old Jul 7, 2011 | 05:03 PM
wally74's Avatar
Defiant and Jag
THANKS !!!!!!
it seems to be the problem.
I think the new head gasket I installed is a tiny bit thicker than the old one.
Wally
W-27
Oct 5, 2016 08:34 PM
Ultraviolett54
Jan 9, 2013 01:05 PM
MaxDog
Jul 4, 2012 10:01 PM
agtw31
May 27, 2009 07:35 AM
74omega
Dec 27, 2008 05:02 PM
