reinstall rockers
reinstall rockers
Hi,
Thanks a lot for helping me so far.
Now I'm reinstalling the PS Head.
I read someting about the non adjustable rockers in my Olds 350 (1975)
Can I just torque the rockers bolts at 25 Lbs without rotate the cranc?
Some say yes and some say no
How do you, guys, do this job?
.How do you, guys, do this job?
You should rotate the crank to Compression TDC for each cylinder and tighten at Compression TDC, otherwise the force needed to open the valve springs will be added to the torque you are measuring, and you won't be tightening the bolts enough.
skryla
Nov 17, 2011 12:12 PM
davesdelta
Body work
Oct 14, 2009 12:03 PM
