reinstall rockers
Old Jul 8, 2011 | 06:55 AM
wally74's Avatar
reinstall rockers
Hi,
Thanks a lot for helping me so far.
Now I'm reinstalling the PS Head.
I read someting about the non adjustable rockers in my Olds 350 (1975)
Can I just torque the rockers bolts at 25 Lbs without rotate the cranc?
Some say yes and some say no.
How do you, guys, do this job?
Old Jul 8, 2011 | 07:08 AM
You should rotate the crank to Compression TDC for each cylinder and tighten at Compression TDC, otherwise the force needed to open the valve springs will be added to the torque you are measuring, and you won't be tightening the bolts enough.
Old Jul 8, 2011 | 07:23 AM
Rickman48's Avatar
Let alone the chance for breaking the 'rocker stand' while tightening, if they're not in the same position.
Old Jul 8, 2011 | 08:26 AM
wally74's Avatar
Thanks,
It sounds logical.
I'll go for rotating the crank but now the ... maybe dummest question of all....how can I best rotate the crank my Olds.
Old Jul 8, 2011 | 09:13 AM
Big socket on bolt on end of crankshaft, turn clockwise.
28mm, if I recall.
Tom Bilse
Aug 13, 2014 05:56 AM
dc2x4drvr
Aug 23, 2012 09:12 AM
skryla
Nov 17, 2011 12:12 PM
miked
Oct 10, 2011 07:45 AM
davesdelta
Body work
Oct 14, 2009 12:03 PM
