Inteak help!!
Old Jun 18, 2011 | 06:21 AM
lightemup2's Avatar
Inteak help!!
I need to know what I need to get when I pull my inteak off, some people have told me that when a motor gets rebuilt with an aluminum inteak that they get rid of the vallypan and have just a gasket. Then some people tell me that I should get a vally pan and put it back on, I know the vally pan holds the hot oil, but what should I get do I get another vally pan and a gasket? Or do I get just a gasket or just a vally pan, please help I'm lost and the motor is a 350 olds thanks guys!
Old Jun 18, 2011 | 06:41 AM
f-85's Avatar
You can go either way. But your better off with the vally pan.
Old Jun 18, 2011 | 06:47 AM
wilder's Avatar
Depends on what you are doing with the car. the hot oil splashing up on the bottom of the intake is not going make to much difference in a street car. So if you are not worried about it just grab some gaskets and put it together. The best thing you could do is buy a aftermarket valley tray (all the big guys sell them for olds) get some nice quailty intake gasket and install
If I remember right when using the old turkey tray with a alum intake caused a lot of leaks
Old Jun 18, 2011 | 06:49 AM
lightemup2's Avatar
Ok it's mostly a street car but take it to the strip once and awhile, so ur saying get an aftermarket vally pan and a inteak gasket??? Do I get the 1 price or 2 peice vally pan gasket?
Old Jun 18, 2011 | 08:14 AM
It probably "wooden" be a good idea to use an "inteak" gasket.
Now if we're talking about an inTAKE gasket, the factory used the metal gasket under aluminum as well as iron intakes. I've found that the people who say they don't work with aluminum have simply not been installing them correctly.
Old Jun 18, 2011 | 10:54 AM
cutlassefi's Avatar
You beat me to it Joe!
I would argue that the hot oil hitting the intake makes any difference. It's not any hotter than the exhaust going thru it.
Old Jun 18, 2011 | 11:50 AM
lightemup2's Avatar
Sorry guy for the "typo" I'm typing from my I-pod but thanks for the in put about the inTAKE
Old Jun 18, 2011 | 01:10 PM
And thanks for having a sense of humor. If you do decide to go with the stock metal gasket, be sure to get the four bosses at the corners seated in the four outermost bolt holes. This is one place where people mess up. And use RTV around the water ports on both sides of the intake.
Old Jun 18, 2011 | 01:23 PM
lightemup2's Avatar
Ok thanks man! And what are the exact torque specs for the aluminum intake?
nolabigdawg
Nov 16, 2014 06:45 PM
MJAKS462
Apr 15, 2010 02:34 PM
silverriff
Mar 24, 2010 06:36 PM
martine
Jan 22, 2009 01:13 PM
ToronadoGuyDenver
Brakes/Hydraulic Systems
Mar 18, 2007 02:52 AM
